back half q's for orr
Old Aug 24, 2010 | 09:50 PM
63bravo!!'s Avatar
Car: 92 rs camaro
Engine: planning bbc
Transmission: planing t56
Axle/Gears: planing moser 12 bolt
hi everyone! i am currently looking at options now for back halving my 92 and i have some quick questions (iv serched for about an hour or two and i half to go to sleep soon so i gave up lol) as most of you know i will be open road racing my 92 and i was wanting rear tires wider than 10.5" for traction. i will have to go with 18" rims atleast to fit the breakes but i was thinking between 13 and 15" wide would be great.... my question however deals with the suspension side of it with such wide tires im woried about the shocks/springs being to close to eichother ( left and right side that is im going with coin overs) in my head it reminds me of doing bench presses with your hands real close together and it makes it allot harder to keep control of. so anny thoughts on that would be greatly appreciated. also im having a little trouble finding good information about what kind of suspension to use (factory style/ 4 link etc) so anny info on that would be great aswell. btw i thought about irs, however it just didnt seem like the best option for me because of power handling expecialy with the amount of rubber i will have on the ground, the way i drive ( verry agressivly) and the power i will be putting down. all thoughts and opinions welcome other than those discouraging the project as a whole plz dont waste your breath.
Last edited by 63bravo!!; Aug 24, 2010 at 09:53 PM. Reason: please excuse my spelling its been a pretty long day lol
Old Aug 24, 2010 | 10:54 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: back half q's for orr
you can have spohn make offset LCA's to fit a wider tire but you will need a minitub. OR you can wide body fender it and go outward.
I think an 18x11 is all you will ever need however.
ps. was this thread title calling for me? I am not setup for road race right now haha
Old Aug 25, 2010 | 07:59 AM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Someone thinks highly of themselves
ORR = Open Road Racing. Or atleast I'm fairly sure it does.
Old Aug 25, 2010 | 08:21 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
i have 335/30/18's fit in the wheel wells with a pretty invasive minitub, i can fit 345/30/18's too, maybe a little wider but that will put the tires about flush or just outside the wheels wells, and i dont want that look. With the stock width axle, they wheels have 8.5" of BS, thats on a 18x12 wheels, the tire is 13.5". Thats as fas as you can go with a minitub without redesigning the rear suspension completely. I have custom offset control arms that Spohn did for me a few year back, had to use coilover because the stock springs wont work anymore. Had to clearance the panhard mounts, since they are almost in the wheels.
If you need to go wider, you have to go out with fender flares.
However, i don't see any reason to go any wider than that, with a race compound, that all the tire you'll ever need
in reality for openroad, you may want to push the tires out more than tucked in, but thats up to you to determine.
Old Aug 25, 2010 | 08:37 AM
built91Z28's Avatar
Sorry, my lame remark was an attempt to mess with Orr89RocZ for thinking the thread was directed at him.
Old Aug 25, 2010 | 06:30 PM
63bravo!!'s Avatar
Car: 92 rs camaro
thx for the info! i dont plan on going outwards with the finders much i will roll the lips but that may be it if anything i doubt my limited body skills will let me go more than an inch or so more (i absolutely suck at custom bodywork that looks nice lol i could makeum as far out as i want but it would look like absolute s**t not what i want) what limits are you running into going farther in?
oh btw yes ORR = Open Road Racing but thank you Orr89RocZ for your input and what sizes are you running for that 9.8 1/4?
Old Aug 25, 2010 | 07:18 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
if you go much farther in, your cutting out most of the frame rail, the panhard mounts will both be in the way, and IN the wheel, the passengerside would be the biggest problem. Then the control arms, its hard to offset them more than i already have, and much further in and you getting into the spring of the coil-over and the shock.
you can go further, but your going to have to redesign and build all the mounting points for the suspension from scratch. the only way to do it would be to preform a complete backhalf and use a different rear suspension setup, 4 link or 3 link, preferably the 3 link.
but putting 2 friggen huge tires under the car, that close together will make the back end really loose in a turn.
besides, there are ORR cars out there making a shitload of power and performing very well without the need for a tire larger than what im running.
Old Aug 25, 2010 | 08:29 PM
63bravo!!'s Avatar
Car: 92 rs camaro
i apoligise for being so persistent but i want to learn as much as i can about this subject so if i move the frame rails in, i could go with 3 link or 4 link(probably not 4 its my assumption that they are primarily for streight line performance) why could i not keep the tqarm setup i could mount the lca's on the new frame rail (**** i forgot how they mounted on the axel lol they are underneath right lol) and use coil overs mounted on the new frame rails. also i heard about a different kind of suspension recently called a angeld arm type. also could you be more specific about the rear end being "loose"?
Old Aug 25, 2010 | 08:42 PM
63bravo!!'s Avatar
Car: 92 rs camaro
also does anyone know how wide a third gen is from widest point tho widest point in the back? so i can figure out how big of fuel cell/ tires/ frame room i will have total without moving the wells out
Old Aug 25, 2010 | 09:35 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Those were just little old 26x11.50x15 ET streets. My street tires are 295/30/19's and they are a fat tire that fit well under the wells. Same tire thats on a Porsche 911, it grips well as long as you dont ask it to go WOT below 50mph in any gear other than 3rd... which for ORR you may not have to worry about. Thats roughly 650-700whp and will get you to some high speeds rather quickly
Old Aug 25, 2010 | 09:55 PM
63bravo!!'s Avatar
Car: 92 rs camaro
ok gotcha iv got a 14 hr work day tomorow so il make this quick but im looking at 1000 hp and i need tires that can run 200mph for atleast 100miles so thats a big factor aswell lol oh thats turning too btw i will probably run 2 sets one for race one for road so the race ones dont need to last much more than 100 or 200 miles lol goodnight all i will check back when i get home tomorrow lol (approximately 22 hrs from now) lol
Old Aug 27, 2010 | 11:15 PM
63bravo!!'s Avatar
Car: 92 rs camaro
Bump
Old Sep 11, 2010 | 11:28 PM
63bravo!!'s Avatar
Car: 92 rs camaro
buuummp? still wanting to know what would be the optimum suspinsion set up and if moving the shocks and struts too close together could adversly affect handeling
Old Sep 15, 2010 | 08:18 PM
63bravo!!'s Avatar
Car: 92 rs camaro
bump, if you dont know could you atleast send me to someone who does?
Old Sep 15, 2010 | 09:56 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
That I may beable to help you on.
Try here
http://www.frrax.com/rrforum/
they should beable to provide information or ideas
Old Sep 16, 2010 | 09:59 PM
63bravo!!'s Avatar
Car: 92 rs camaro
awsome thx dont have time to look right now but i will nxt week when im not as bussy thx
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
