Reverse rake...THIS SUCKS!!!
Old May 15, 2001 | 03:58 PM
MelloYello's Avatar
So I installed my set of Jamex lowering coils and now my car sits lower in the back than in the front. I have a big stereo in back. Could worn (leaking) rear shocks cause this? Do my front springs just need to settle more (I installed them a few days ago). I only lightened the front end by installing headers and an aluminum water pump. PLEASE HELP ME BEFORE I GO INSANE!
Kyle
1990 Firebird Formula 350 speed density TPI; K&N, air foil, throttlebody coolant bypass, underdrive pullies, MSD 6AL, MSD HEI coil, 8.8mm wires, adjustable fuel pressure regulator, Hypertech Thermomaster chip, 160* thermostat, fan switch, B&M stage 2 shift kit, Edelbrock 1&5/8 headers, gutted dual cats, Flowmaster 80 series muffler, 3.73 posi rear end
Old May 15, 2001 | 04:08 PM
Chuck Everly's Avatar
They will settle but the big stereo may be causing a problem. I had them on my RS and it sat level with a lot of aluminum motor parts and fiberglass hood.
Give it some time. I think Jim85IROC has the same springs and he also has a large stereo as I recall and his sets fine.
Are you sure the spring is all the way in the pocket at the top? I had this problem on one side when I installed mine the first time. This will cause the car to sit high in the front.
Old May 15, 2001 | 10:36 PM
MikeDwhoROCZImports's Avatar
Give it a little time. When I put my new rear end on my car, the rear sat low for a couple days. After driving it around it raised right back up.
If after a week you still have a bad rake, something's up.
Old May 17, 2001 | 12:42 PM
MelloYello's Avatar
Is there a way to install the fronts "upside down"? If so, I might have done just that. I have the flat edge side against the A-arm and the angled edge side facing up. If not that, then I dont know what the H*LL is up. Thanks
Kyle
Old May 17, 2001 | 02:05 PM
I honestly can’t remember what end goes where. I “think” the flatter end went up because I remember taping the isolating rubber to the spring. Please take this with a grain of salt it has been 2 or 3 years since I did this.
Can you post a picture?
Here is what my RS looked like with Jamex springs. Not the best picture but it should give you an idea. Remember I had a lot of aluminum in that motor and a fiberglass hood. There was nothing in the rear hatch area and the interior was stock right down to the radio.
Old May 17, 2001 | 08:38 PM
MelloYello's Avatar
I took measurements on the distance from the ground to my fender lip...here are the results:
Driver's side front: 26.75"
Passenger side front: 27.125"
Driver's side rear: 26"
Passenger side rear: 26.5"
As you can see, the front is about .75" higher than the rear. In addition, the passenger side is .5" higher than the driver's side! WTF?! I am even more concerned than before. It has been 5 days since they have been installed and I am starting to worry. Please, someone help me!
Old May 18, 2001 | 10:34 AM
87kevroc's Avatar
Car: 1987 Chevrolet Camaro Z28 IROC-Z
Transmission: TeamTripp Performance
Love those ROH ZS's. Are they 16" or 17"?
Old May 18, 2001 | 11:10 AM
Mellow Yellow, I really don’t have an answer. If they are installed correctly then maybe the weight in the back is too much. As I recall mine measured 26-3/8” on all four corners. I could be wrong but I do not think shocks/struts could make that much difference.
Did your springs have part numbers on them? If so and you know what they are post them. I have a set of Jamex springs in the garage that I can compare numbers with. Maybe you got the wrong springs. I doubt that is the case but it does not hurt to check.
87kevroc, Those were 16”.
88 IROC convertible
-=ICON Motorsports=-
Old Jun 2, 2001 | 09:48 PM
MelloYello's Avatar
Thanx for your help, guys...I left this topic alone until I could better asses the situation. A few nights ago, I took a speed bump too fast and slammed the front end on the bumpstops...I took measurements of the ride height again and recorded a much even 26.75" front and 26.25" rear...can i install spacers in my rear springs to raise the rear about an inch...if so, then who makes them and how well do they work? If I dont find that to be a suitable souloution, I might cut 1/4 to 1/2 coils off my front springs
(as brought up earlier by Tom Kelhier [spelling?]) Thanks for your help, guys...u are great.
Old Jun 4, 2001 | 11:22 PM
MelloYello's Avatar
Anybody?...Spacers?...Cutting coils?
Thanx
Old Sep 18, 2001 | 05:45 PM
yellowiroc2's Avatar
Car: Z06, WS6
Engine: LS6, LT1
Transmission: M6
what'd you end up doing? does the problem still persist? I too wonder if there isn't something i can put under the rear springs to raise the rear end. I'm using eibach sportline 1.6 front, 1.3 rear drop and have the very same problem. i called eibach and they recommended loosening the control arms and retightening once the car was down.
Old Sep 21, 2001 | 09:59 PM
MelloYello's Avatar
My front end was sitting on the bumpstops, so I cut an inch off the tips, reattached them and went for a drive....
I put my gear selector in "1" and bounced the front end up and down with a few blips of the throttle...
the front end is now only about .25-.3" higher than the rear....I plan on cutting 1/2 coil off the front springs for that extra bit of scrapage...
1990 Firebird Formula 350 speed density TPI; Edelbrock HI-FLO base and Runners w/portmached plenum; air foil; Comp Cams 1.6rr; Edelbrock 1&5/8" headers; MSD 6AL, HEI coil & plug wires; underdrive pullies; Hypertech stage II chip; AFPR; B&M stage II shift kit; 3.73:1 rear; Jamex 1.5" lowering coils; Spohn subframe connectors, LCA's, and LCA relocation brackets; free mods; !cats; !Smog Pump; PLUS...1300w stereo weighing 200 lbs.
Old Oct 7, 2001 | 02:09 AM
mynyka's Avatar
yes, its possible to put the springs in upside down. the flat end goes on top and the
other end (the end you would cut to remove a coil) goes in the matching slot on top of the
A arm on the bottom. The A arm slot is molded to accept the uneven side of the spring as it spirals downward -which is why the flat side goes on top and reverse installation would result in the spring not sitting all the way down in the A arm (because the flat side would sit on TOP of the molded slot not in it) and a dramatically increased ride height.
Drew
Pac J
May 17, 2020 10:44 AM
tyeo098
Nov 30, 2015 06:27 PM
wanext
Oct 6, 2015 12:18 AM
3.8TransAM
Oct 1, 2015 07:47 PM
84redta
Sep 19, 2015 09:58 AM
