Battery in wheel well?
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
Has anyone mounted their battery in the rear wheel well where the spare usually is?
1991 Formula, 406, miniram. Best run to date (9/30/01) 60' 1.63, ET 12.28, MPH 110.48
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
BMR makes a set-up for 4th Gens that looks real clean, don't know how close it is to work in a third or if they plan on designing one. I'm sure it's been done, been toying w/ the idea myself.
'91 Z28 1LE; 355, Sportsman II heads, Edelbrock TPI w/ 58mm TB, Tremec TKO 5-speed, 3.73's & much, much more
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
My friend did it to his third gen. He put it where the spare goes and said it wasn't a problem. He did make a bracket for it though.
i have mine in the sump in the rear, in a moroso battery box
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
ICON Motorsports
1st & 3rd
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
I would put it there but I have 2 amps, cd changer and 2 12" subs there. That is why I was thinking about putting it where the spare used to go.
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
If you already have 4 ga. or bigger going to an amp in the back, it's an easy change. Just put your battery back there and use the existing 4 ga. wire in reverse.
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
Actually if I put the battery back there, I would use 0/1 gauge wire.
The question still remains, will the sheet metal in the well where the spare went hold that kind of weight and has anyone done this or made a bracket of some sort to support the weight.
Will the Moroso box ift back there?
I'm planning on putting an optima in my spare tire well. I test-fit one and it looked like it would fit great! I think I'm going to remove the tire mounting bracket and weld in something resembling a battery tray. I have to weld in there due to rust, anyway..
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
then where are you going to hide your bottle?
1991 Firebird
350 L98 (was a 305 TBI),T-5,Edelbrock TES and cat back,Accel manifold
NOS,subframes,jegster torque arm,MSD Digital 6
AFPR,Lakewood lcas
Hurst linelock,SLP cam (206 212 .480 .486),relocated battery,cold air,Hypertech chip,centerforce df,clutch
poly bushings and mounts
AFR 190s
Harland sharp 1.5 rockers
autopower rollbar
12.33 @ 114.83 juiced uncorrected
13.510 @ 102 non juiced uncorrected
1991 Firebird
AFPR,Lakewood lcas
AFR 190s
autopower rollbar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
I was thinking about using a dry cell but nothing in the NHRA rulebook differentiates between wet and dry cell batteries and the need for a sealed box.
that may be true; a year ago it wasn't. maybe too many people complaining because the battery's are a lot more expensive.
it's your choice, pay the extra bucks for a cleaner setup without the worry of leaking or vapors as well as a more reliable battery, or go cheap and run with it to see what happens.
once you buy a drycell you won't go back; i have them in all my vehicles and especially if it's relocated to the interior.
colton_carlson
Mar 8, 2019 12:21 PM
Dialed_In
Aug 20, 2015 01:45 PM
db057
Aug 11, 2015 10:11 PM
