tires tilted after control arm replace
Old Aug 21, 2011 | 12:28 PM
0pyders's Avatar
Car: 86 Firebird LG4
Axle/Gears: 3.23 limited slip
They're making a wide V shape. I never touched the struts. Would it be something to do with the ball joint stud being pivoted wrong when I reinstalled the a arms?
Old Aug 21, 2011 | 12:32 PM
Guest
Guest
Posts: n/a
Re: tires tilted after control arm replace
If you also changed springs, then they'll need a couple of weeks of driving to take a set. With used old springs, IDK if they need to re-set or not.
Old Aug 21, 2011 | 12:46 PM
0pyders's Avatar
I reused my springs.
Old Aug 21, 2011 | 07:38 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
did you index them correctly? roll the car or drive it around and the bushings and such will settle/relax and it should be better. The balljoint cannot be installed wrong.
did you unbolt the struts from the spindle? if you did, you have changed the alignment and will need to have it all check and corrected
Old Aug 21, 2011 | 10:46 PM
0pyders's Avatar
Yes I made sure I installed the springs in right (I followed the "suspension how to" sticky). Did not unbolt the struts from the spindle. I think I'll drive it around the block for a little while and see if that does it. Thanks for the replies guys, I appreciate it.
Old Aug 25, 2011 | 10:08 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
your title says control arm replace... need some more info here. if you installed a different arm than was there, that could be what affected your camber. what was the reason for replacing? ride height look normal?
Old Aug 27, 2011 | 08:04 PM
0pyders's Avatar
One of the arms was different than the ones I took off. The arm I bought was a 1990 stock firebird arm while mine was an 86. I replaced it because I accidentally bent my old a- arm trying to replace the bushings. Ride height does look normal. I looked at my bent arm and the replacement and they both looked the exact same in every way (except the bent part lol).
Old Aug 28, 2011 | 11:42 AM
Car: 91 Camaro
If you didn't mess with the struts at all then I would say that your problem is in the length of the a-arm. The length of the a-arm will move the bottom of your tire in or out for obvious reasons. There isn't any damage on the k-member, right?
Old Aug 28, 2011 | 08:08 PM
0pyders's Avatar
no damage on the k-member.
Can't it just be fixed with an alignment? Like maybe have more or less camber on one side to balance it out?
Old Aug 28, 2011 | 08:52 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Have you moved the car yet? Until it is moved, maybe 50 feet or so at least, everything will "look" wrong. 3rd Gens need to move for everything to settle into place.
Old Aug 28, 2011 | 09:07 PM
Car: 91 Camaro
It could possibly be fixed with an alignment. depends on the current position of the top strut mount and how far out of alignment it is. BlackenedBird has a good point. I just assumed you had moved the car already...if you haven't, you need to do that. Any car needs to be moved back and forth some (or just driven around some) to let the suspension settle after being jacked up.
Old Aug 28, 2011 | 09:20 PM
0pyders's Avatar
Car has not moved an inch in 2 years. I bet that's it.
1992rs/ss
Jan 31, 2025 05:10 PM
Vintageracer
Jan 10, 2020 05:33 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Fronzizzle
Aug 9, 2015 01:15 PM
