83 camaro front struts
Old Sep 3, 2011 | 03:37 PM
Reerun_KC's Avatar
having trouble removing the bolt on top of the strut tower...
Anyone have any suggestions?
Cody
Old Sep 3, 2011 | 06:47 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 83 camaro front struts
impact gun will do it, or if the struts are already trash, put a pipe wrench on the strut shaft then break the nut loose.
Old Sep 4, 2011 | 03:17 PM
Reerun_KC's Avatar
Yes the struts are trash, we are replacing them.. We got the passenger side off now, but the driver side sheared off at the top of the nut...
So now what? Do we need to just hot wrench it off now? Can you find a replacement bolt ?
Old Sep 4, 2011 | 03:52 PM
Reerun_KC's Avatar
okay we just took it all apart... the top mount piece that was held in by 3 bolts, We removed that and pulled everything out..
Guess we will just replace it with all new...
Old Sep 4, 2011 | 07:27 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
The issue is that the strut rod spins inside the strut - now that you have it out, stick it in a vise to hold the strut rod and turn the nut off with a wrench/rachet.
Old Sep 4, 2011 | 08:30 PM
Reerun_KC's Avatar
good idea.. I think the strut mounts are in pretty good shape... How often does one replace those?
Old Sep 4, 2011 | 08:43 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
There is rubber in the mount, so after nearly 30 years, I'd say replace.
JamesC
Old Sep 4, 2011 | 09:09 PM
Reerun_KC's Avatar
JamesC
Yeah we were just trying to get that driver side strut mount loose from the strut...
I think at this point two new strut mounts would probably be in good order with two new struts...
Better new than sorry later...
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
TheExaminer
Aug 25, 2015 07:34 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
wruiz
Aug 11, 2015 02:59 PM
