Another Subframe connector post!
Old Feb 27, 2012 | 10:44 PM
Pat1990GTA's Avatar
Car: 1990 Trans Am GTA
Engine: 383 HSR Profiler heads
Subframe connectors...Spohn, UMI or Alston?
Does somone have pictures with subframe connectors on their car with dual cats? I have the dual cat magnaflow setup and its already almost hitting the pinch weld so im trying to figure how to fit in some SFC
Alston look pretty nice and might work with the dual cats?
Please help!
Old Feb 27, 2012 | 11:02 PM
frankinmaro's Avatar
Car: 87 Frankinmaro
Engine: ZZ4 short block 67 327 462 castings
Transmission: TH350-c out of Y body
Axle/Gears: 97 4th gen Torsen 3.23
Re: Another Subframe connector post!
I just got my alstons ,(and they go on the inner rail not behind the pinch like UMI or Spohn). And Ill be putting them on when the weather gets better plus I have some square tube stock that I made for the pinch and to tie both together,but I have no cat. But the alstons are nice and LonSal is the man. thats my thoughts
Old Feb 28, 2012 | 07:25 PM
ItalianIroc-Z's Avatar
hello I wanted to know if putting both inner and outer subframe connectors is a good idea ... i currently have inner tubular connectors and I just bought a pair of outer connectors from competition engineering .... what do you guys think thanks
Old Mar 1, 2012 | 10:50 PM
Pat1990GTA's Avatar
I was just thinking about putting the outer SFC but both would be nice! Ive heard some bad things about competition engineering SFC and their fitment, just do some searches on them and see what people are saying. But i think a nice set up would be Spohn outers and alston inners =)
Old Mar 1, 2012 | 10:53 PM
ok thanks for your help i was trying to put them on and i didn't have any problems up too now but thanks for the advise
Old Mar 1, 2012 | 11:57 PM
Car: 87 Frankinmaro
heres another option if you want to spend a bunch more$$$$,.....http://www.swracecars.com/store/82-9...71=40-600.aspx ,thats why I went with TDS for the alstons
Old Mar 2, 2012 | 12:03 AM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
I prefer the Jegster subframes over all the rest....
Old Mar 3, 2012 | 01:02 PM
Pat1990GTA's Avatar
Do the jegsters fit with dual cats? Does anyone have pics of the jegsters installed, i couldnt find any pics. They look really nice
Old Mar 3, 2012 | 03:02 PM
Car: '88 Trans Am
Engine: 5.7L TPI
They fit awesome, right along the frame channel.... they are a tight fit in dual cat cars however if you drop the pipe instal that side connector bolt it in there its a breeze.. then weld them to the frame on both ends...
I have no pics of them installed but we used them back in 1992 when Jegs released them the last set I had was in '99 on my '89 TA ...
Old Mar 3, 2012 | 04:18 PM
Pat1990GTA's Avatar
Can you easily weld them to the pinch weld?
Old Mar 3, 2012 | 04:43 PM
Car: '88 Trans Am
Engine: 5.7L TPI
Yes.... you can weld them in a few other areas aswell..
All you need is roughly 2" of weld in each area *****move carpet away from floor or completely remove carpet from car******
Old Mar 10, 2012 | 01:15 PM
Pat1990GTA's Avatar
I ordered a set of jegsters today =) Took me a few days to decide between them or spohn and i think the price is what did it in the end
Old Mar 10, 2012 | 07:47 PM
Car: '88 Trans Am
Engine: 5.7L TPI
Excellent choice you will not be let down.....they fit AWESOME!!!!!!
Old Mar 10, 2012 | 09:38 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
Axle/Gears: 4th gen rear with 3.42
Alston here, no problems!
Old Mar 11, 2012 | 12:32 AM
Pat1990GTA's Avatar
Alston may be added later to my car, but i wanted the outer SFC first..i think the jegster/alston combo would be awesome!
Old Mar 11, 2012 | 11:55 AM
Adrenaline1's Avatar
Car: 1982 Firebird
Engine: 2.8 N/A
Transmission: Manual 4 Speed
Are the jegsters bolt in or weld in?
I was going to go with alston and comp engineering but whats the problem with the comp SFC?
Also, i cant even find the jegsters anywhere.
Old Mar 11, 2012 | 01:40 PM
Pat1990GTA's Avatar
The jegsters are bolt in and weld in
I wanted the jegsters or spohn because they fit well with the dual cats
www.jegs.com for the jegsters awesome price 179.99
Old Mar 11, 2012 | 01:44 PM
Car: 1982 Firebird
Engine: 2.8 N/A
So i could bolt them in now and weld them in later if i wanted? Could you post a direct link, i tried searching w/o any luck.
Old Mar 11, 2012 | 01:47 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Here is a link that will actually take you too them, not just to the Jegs main page.
http://www.jegs.com/i/Jegster/550/40053/10002/-1
I just wonder how Jegs can call the subframe ties when they don't even touch the front subframe in our cars.
Old Mar 11, 2012 | 01:56 PM
Car: 1982 Firebird
Engine: 2.8 N/A
Ah, i was searching connectors, not ties. Thanks!
Old Mar 11, 2012 | 02:09 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
the jegsters weld to the front piece of metal that is welded to the subframes, so they do weld to the same material
deracer
Apr 11, 2016 12:04 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
