manual steering
Old Apr 13, 2012 | 12:14 AM
84TransAm383's Avatar
manual steering
What manual steering fits into the third gen. I no the s10 just not exactly sure of the years. trying to do the cheaper swap to get it rolling before dropping it on a flaming river
Old Apr 13, 2012 | 06:15 AM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
Re: manual steering
I bought a rebuilt one from one of the local auto parts stores, I asked for one for a 85 S-10. I know there were some small variations between years but the one I got for a 85 S-10 fit perfect.
Old Apr 13, 2012 | 07:06 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: manual steering
84+ S10 box. You need the steering box with the 4 bolt top cover.
Old Apr 13, 2012 | 09:46 PM
Re: manual steering
everywhere i go to try and order a reman cant order them or even locate one. It seems i have to go to a salvage yard
Old Apr 14, 2012 | 12:35 PM
J-(Chicago)'s Avatar
Car: 85 88
Engine: 455 Olds
Transmission: TH350
Re: manual steering
Do the manual s10 boxes use a power steering pitman arm?!?!
I had to make my own since the splines were different on the box that I used.
Old Apr 14, 2012 | 02:17 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Re: manual steering
The early box with the 3 bolt top cover is not a direct swap. The input and output shafts are smaller. If you use the late model 4 bolt top cover box, it's a direct swap with the same size shafts. The S10 pitman arm is a slightly different length which will change your steering geometry but many people still use it with no problems. With the late model box, you can simply pull the pitman arm off your power box and install it on the manual box to maintain the correct steering geometry.
Old Oct 15, 2012 | 07:07 AM
speedpower09's Avatar
Car: 88 Trans-Am
Engine: 305 to a 4.3 turbo
Transmission: 700R4 soon 94 T56
Axle/Gears: 94 Trans-Am Posi
Re: manual steering
Ok I was just wondering why would you swap a power steering box for a manual one?
Would this be for drag racing or road racing
Old Oct 15, 2012 | 07:11 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Re: manual steering
Drag racing for weight reduction. You need a quicker ratio and faster response of power steering for road racing.
Old Oct 21, 2012 | 07:49 PM
Maria8's Avatar
Car: 1985 Pontiac Trans-Am
Engine: AFR 235,Dart 400 Procharger F2. EFI
Transmission: Coan 400 + Gearvendors
Axle/Gears: racecraft 9"
Re: manual steering
how much weight will the s-10 box help you loose?
Old Oct 22, 2012 | 03:34 PM
mcbchild's Avatar
Car: 1984 Firebird SE
Engine: 388 sbc, Brodix Track 1s
Transmission: turbo 350 transmission
Axle/Gears: 4.10 gears
Re: manual steering
If you are even considering any type of street driving with turns, don't even switch out to manual as the weight reduction is not worth it for street driving. You basically are removing the weight of the power steering pump, brackets and hoses.
This is a great step though for drag racing as I have tried it myself with the s10 box, but did some street driving and trying to make a turn to get into my garage was too much, so I switched back to the PS setup.
Old Oct 22, 2012 | 03:40 PM
Maria8's Avatar
Re: manual steering
thanks for sharing your experience.
Old Nov 9, 2012 | 01:31 AM
4lnkdSupra's Avatar
Re: manual steering
What kmember will the s10 rack fit??
Old Nov 9, 2012 | 12:58 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Re: manual steering
S10 doesn't use a rack. It uses a standard GM steering box that bolts to the frame just like a power box.
Old Nov 9, 2012 | 05:28 PM
4lnkdSupra's Avatar
Re: manual steering
I guess thats why they call it a pinto rack on kmembers?
Old Nov 9, 2012 | 10:06 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Re: manual steering
Pinto and Mustang II are the 2 most common choices. The aftermarket choices are generally based off the Pinto design.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
Veaceonee
Sep 29, 2016 08:15 PM
Ian Irvine
Sep 4, 2015 08:08 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
