do springs make a huge diffrence?
Old Jan 8, 2013 | 12:35 AM
blaze15301's Avatar
Just like the title ask do springs make a huge difference? I am debating buying moog Irok springs from rock auto to match the rest of my suspension its all moog. So will the spring make a huge Difference for a daily driver?
Old Jan 8, 2013 | 06:01 AM
Re: do springs make a huge diffrence?
Yes
Like it's a whole diffferent car
Old Jan 8, 2013 | 06:23 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
You might take note that the Moog fronts (5664) will drop the car slightly, the rears (5665) will jack the rear up significantly. I was forced to cut a bit of coil and use hose in place of the OE isolator to eliminate the problem.
JamesC
Old Jan 8, 2013 | 07:10 AM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
I like the hotchkis 1903 springs,
1" drop.
Old Jan 8, 2013 | 08:37 AM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
JamesC
I just bought and installed the 5665 springs and JamesC is telling the truth. I have a 4"+ fender gap. Will be removing the isolator first, and possibly cutting a coil to get it less 4x4 like.
Old Jan 8, 2013 | 09:59 AM
blaze15301's Avatar
The ones i am getting are 5662 for the front for 16 inch wheels and the other is 5665 for the rear. can someone post pics please.
Old Jan 9, 2013 | 05:47 AM
Chuck84TA's Avatar
Car: 1984 Trans Am Recaro Edition
Engine: 355 L98 Vortec 226/234 custom cam
Transmission: TKO-600
Axle/Gears: On borrowed time...
I found this link very helpful regarding springs
https://www.thirdgen.org/forums/susp...og-5662-a.html
Old Jan 9, 2013 | 10:40 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
It's not the most detailed photo. But it gives a rough estimate. Mine is the black one on the end. This is with 5662 and 5665 springs. (The maroon car next to mine is sailtexas186548's ultra low Camaro)
Here's a closer look at the back 5665 springs (back when I still had the GS-D3 tires on there). To me, it looks fine like this. If you kneel down on the ground and look closely, it may appear to have lots of gap. But from my usual standing position, walking up to the car (as this photo was taken), this is what I see. The rear heights were 28.5" when this photo was taken.
Don't forget that the back end will be 0.75" lower once you actually sit in the car. Regardless, I like it at the height it is.
customblackbird
Aug 15, 2021 10:16 PM
86White_T/A305
Aug 17, 2015 12:16 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
z28addict8490
Aug 7, 2015 08:48 PM
