Help with front lower control arm bushings
Old Mar 14, 2013 | 06:21 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Hi Guys,
I'm trying to put new Prothane 7-220-BL bushings in my front LCA. I have the old rubber bushings out already. Am I supposed to remove the metal "casing" (see red arrows in pic) also?
I did a search but can't find the answer.
Thanks a million!
Attached Thumbnails Help with front lower control arm bushings-control_arm.jpg
Old Mar 14, 2013 | 06:35 PM
mille_3's Avatar
Car: 1986 Firebird
Engine: 6.0L LSX
Re: Help with front lower control arm bushings
yes. easiest way is to collapse them and pull them out
Old Mar 14, 2013 | 07:15 PM
Ok. Thanks mille! Much appreciated.
Old Mar 14, 2013 | 08:10 PM
midnightfirews6's Avatar
Car: 1984 Trans Am WS6
Engine: LG4
Axle/Gears: 3.23 LSD
If you (or anyone else viewing this thread) owns or has access to an air chisel, those make short work of the casings. Just hammer the flared ends in and hammer them out. I'm sure there are many ways to go about it though.
Old Mar 14, 2013 | 09:11 PM
Thanks midnight! I don't have an air chisel so I used a sawzall to cut a chunk out of the casings and then used a regular hammer & chisel to get them out.
Old Mar 15, 2013 | 01:37 PM
87camaro kid's Avatar
Car: 1987 Z28
When putting in the new sleeves I would highly recommend having a local auto machine shop push them in for you. I recently tried using a ball joint press but started to bend the a-arm. The shop fixed it and pushed the new ones in, and pressed in new ball joints, for a whopping $20.
Old Mar 15, 2013 | 01:59 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Agreed. Very easy to bent the arms when trying to install the bushings.
Old Mar 20, 2013 | 04:43 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Yes, I just did mine, it does take some thinking. You have to make sure you have good spacers to put between the arms when you press in the bushing and it does take a lot of force.
Old Mar 20, 2013 | 04:45 AM
stealtht/a's Avatar
Another.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
