Sway bar bushing measurements
Car: 1991 Z28
Engine: L31-R 350 w/ EBL P4
Hey guys, I've got a quick question.
I measured my front and rear sway bar today with a micrometer because I need to get new bushings for them. My front sway bar consistently measured in at around 36.1mm in diameter and my rear sway bar was in the 23.2mm range. I'm assuming that I want to get 36mm bushings for the front and 23mm for the back? Or do I round up and get 24mm for the back?
Also, my car isn't a 1LE. How is it possible that I have a 36mm front sway bar?
Car: 1988 Firbird formula 350
Engine: 5.7L TPI
Axle/Gears: 3.27 Nine Bolt
Re: Sway bar bushing measurements
I've got a 36mm front and 24mm rear sway bars on my 1988 Formula 350 with the WS6 suspension package. I think this was the same as on the 1988-90 IROC-Zs and maybe on the last of the 3rd gen Z28s. The 36mm front bushing are a little hard to find. I just replaced mine, took a while to fine some that would fit the stock brackets.
Car: 1991 Z28
Alright, cool. So if I measure 23.2mm for the rear sway bar, do I want to go with 23mm or 24mm bushings?
Car: '90 Formula '88 GTA
Engine: 305 TPI 350 TPI
Transmission: T5 700R4
Axle/Gears: 3.42 10 Bolt 3.27 9 bolt
edit: accidentally replied on wrong thread, sorry for the ressurection
vjo90RS8
Exterior Parts for Sale
09-10-2007 08:49 AM
