What SFC are people running when they don't have stock exhaust? (mufflex Y pipe)
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
I am runnig long tube hookers, into a modified mufflex y-pipe (to fit around my Spohn TQ arm), then run this into a mufflex spintech cat-back system (no cat of course).
So my exhaust is all inboard. People seems to be very conserned with SFC and stock exhuast clearance. I don't care about this at all.
What are people doing that don't have these issues to worry about?
Is it better to just fab up my own stuff. I can do some simple flux core welding. Thats how I moded the exhuast.
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: What SFC are people running when they don't have stock exhaust? (mufflex Y pipe)
I fabed my own Y pipe to get past my SFC. Although I am thinking of trying to do another. Mine was quick and dirty and I want to try to run dual 2.5s a little longer before the merger. UMI Subframes
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I run spohn subframes. They come with two small bars to tie intothe trans subframes. I mounted those bars as high as i could against body to clear exhaust that ran past it. I had a 4" custom y and now duals with xpipe in that location. Fits good. I'd fab your own if you can weld and have a sawzall lol. Exhaust is easy
UMI Subframes and custom modified Y pipe I bought used and cut up.
I have SSM SFCs (best ever made for our cars IMO) and have had both the SLP and Mufflex y-pipes. Both clear without issues.
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
Check these out. Good inside and outside designs.
http://www.bmrsuspension.com/?page=p...d=60&catid=176
I bought UMI but haven't installed them yet. Now that i'm doing an LS1/t56 swap I'm curious to see if they will fit with the LT headers and Ypipe I use.
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
With all your exhaust in the trans tunnel, what SFC will not clear? I don't recall any design intruding into the tunnel
Engine: LS3
None. I just wanted to know what people found best when they don't have to worry. I like BMR stuff, so I might use that and add addtional supports to it.
Car: '88 Iroc
Engine: Single turbo Vortec 5.7, Megasquirt
Transmission: Probuilt 700r4 3000 stall Vigilante
Axle/Gears: Moser 9" 3.25 w/True Trac
I bought the Jegsters and added two supports to go over to the trans tunnel. Plenty of ground clearance even with 4" exhaust.
transaero
Aug 31, 2015 01:14 AM
