Sway bar ends worn out.
Old Mar 22, 2015 | 09:51 AM
SOCAL-Z's Avatar
Car: 87' IROC
Was working on the car yesterday and see that my front sway bar ends are shot.They even had small pieces of the red bushing falling off. What Sway bar end would you buy rubber or poly?
Old Mar 22, 2015 | 11:28 AM
RamIt's Avatar
Car: 1984 z28
Engine: Crate replacement L31R 350
Axle/Gears: 7.625" 28 spline 3.23
Re: Sway bar ends worn out.
On my 84 they seemed to be clear plastic.
I just went to the local autozone/oreiley's and picked up the energy suspension 9.8117 end link kit (around $22). The stock end link bolts were very thin and slightly bent so I got the kit. They sell the bushings ala carte for around $13.
I would not use soft rubber.
Old Mar 22, 2015 | 11:38 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Poly endlinks and greaseable sway bar bushings.
JamesC
Old Mar 22, 2015 | 01:23 PM
plum92_camaro's Avatar
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
Old Mar 22, 2015 | 08:37 PM
SOCAL-Z's Avatar
Car: 87' IROC
Found the links now I need to find the bushings
Old Mar 22, 2015 | 08:55 PM
SOCAL-Z's Avatar
Car: 87' IROC
Ordered the same, energy suspension 9.8117.
Old Mar 22, 2015 | 10:18 PM
SOCAL-Z's Avatar
Car: 87' IROC
As for the greaseable poly sway bar bushings do I just buy the bushing and use my old mounts?
Old Mar 22, 2015 | 10:23 PM
RamIt's Avatar
Car: 1984 z28
You can buy them with the brackets. The grease able bushings have channels in them for grease.
http://www.hawksthirdgenparts.com/fr...gy-suspension/
http://www.top-downsolutions.com/gre...amaro-or-fireb
Old Mar 24, 2015 | 10:17 AM
SOCAL-Z's Avatar
Car: 87' IROC
Measured the swaybar this morning to be sure I bought the right size. Swaybar is 34mm. Ordered Energy Suspension part should be here Thursday.
Old Mar 24, 2015 | 10:52 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Yeah....replaced mine 2 weeks ago with Energy Kits.
And made quick work with this!
Old Mar 24, 2015 | 11:21 AM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
I am fixin to do my rears what length should they be I have 2 5/8 inch?
Old Mar 24, 2015 | 11:25 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Energy Suspension 9.8117G Sway Bar End Link Kit Black
Old Mar 24, 2015 | 11:29 AM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
OK Thanks!
Old Mar 25, 2015 | 10:33 AM
SOCAL-Z's Avatar
Car: 87' IROC
That's what mine look.like. Will be doing the rears when I install my founders lca,brackets and panhard.
Orr89RocZ
Apr 25, 2016 08:28 AM
deracer
Apr 11, 2016 12:04 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Warlocksirix
Sep 3, 2015 12:26 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
