Ground Control Suspension
Old Aug 10, 2018 | 11:38 AM
cwad8505's Avatar
I recently watched the video by LSXMatt where he bought the rear portion of the ground control weight jack set up from another member who only needed the fronts. I spoke to ground control and they absolutely refuse to sell only the front or rears. I already have a coilover set up on the front and want to get the rear weight jacks. Would anyone have any interest in buying the fronts if I bought the kit?
Thanks,
Chris
Old Aug 11, 2018 | 02:06 PM
FAST LiFE's Avatar
Re: Ground Control Suspension
If you don't have to absolutely have Ground Control rear weight jacks, you could use Allstar Performance spring spacer for the rear:
https://pitstopusa.com/i-5066715-all...uster-nut.html
and just get the right spring for them:
https://pitstopusa.com/c-131813-chas...cle-track.html
Old Aug 11, 2018 | 07:13 PM
t/aws61985's Avatar
Car: 85-6 TA 85 IROC 82-86 MSE 83 Pace
Engine: Slow ones
Transmission: Noisy ones
Axle/Gears: Weak ones
http://umiperformance.com/catalog/in...ex&cPath=6_479
Umi makes them now as well.
Old Aug 11, 2018 | 09:10 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Originally Posted by t/aws61985
Those are for the front. UMI does make them for the rear but they are much more expensive. Why? I dunno.
Old Aug 12, 2018 | 11:01 AM
t/aws61985's Avatar
Engine: Slow ones
My bad.
Old Aug 13, 2018 | 01:38 PM
cwad8505's Avatar
Thanks for the responses, guys! I may end up going with ground control and posting the fronts for sale. Not sure yet.
Old Aug 13, 2018 | 02:56 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Do you have a part number? I don't see a kit for the rear. Unless your post was a typo.
Old Aug 13, 2018 | 03:01 PM
Jorlain's Avatar
Car: '84 Trans Am
Engine: 357 SBC
Axle/Gears: 10 Bolt 3.73, Torsen Diff
All I'm seeing for the rear is coil overs, which are definitely more expensive.
Old Aug 13, 2018 | 03:24 PM
kaos420's Avatar
Car: 88 gta
Engine: 5.8
Axle/Gears: 3.73 POSI
UMI has not released there rear weight jacks yet
Old Aug 13, 2018 | 03:55 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Are they designing a set that you know of? If so that's exciting.
Old Aug 13, 2018 | 04:27 PM
Tibo's Avatar
Car: 1991 Z28 Vert
I was wrong.
Old Aug 13, 2018 | 06:27 PM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
Yes umi will have rear weight jacks out for sale anytime now and the adjuster will be on the top kind of like there front kit.
Old Aug 22, 2018 | 09:03 AM
Beater79TA's Avatar
I saw the rear kit at the UMI Open House 2 weeks ago. It is close to becoming available with it currently being tested on their shop 4th gen at the track and the shop 3rd gen for fitment and less strenuous driving. No idea on what their pricing will be when they hit the market but probably similar to the front kit since the design is very similar. We might have a pre-release set on our GTA for testing at LSFest depending on timing and availability between now and then.
Old Aug 22, 2018 | 10:24 AM
Tibo's Avatar
Car: 1991 Z28 Vert
To be clear, is the design like the front set of weight jacks UMI makes or the rear set that ground control makes?
Old Aug 22, 2018 | 10:32 AM
Beater79TA's Avatar
Similar to the front set UMI makes with the adjust at the top using a threaded rod. Completely different from the rear design used by Ground Control which operates more like a coilover shock spring.
Old Aug 22, 2018 | 03:25 PM
Abubaca's Avatar
Generally speaking, I'm a big fan of UMI, and have most of their 82-92 catalog under my car. That being said, I've had the Ground Control weight jacks for a few years now and have been really impressed. Easy adjustment, nice ride, and quality looking ano and powdercoat.
Old Aug 22, 2018 | 03:31 PM
Beater79TA's Avatar
I can't really fault the Ground Control units and how well they survived 6 years of the beating we laid on them. But at that point they had to be replaced. We had beaten them to a pulp and the fronts had developed some scary bends to the upper spring plates. Most people will likely never punish their suspension the way we do though with thousands of track and autocross laps every year. I wouldn't hesitate to use Ground Control again on a cruiser or something that only saw the track a couple times a year though. To go back to them now on the track warriors would require a maintenance plan to replace them every few years with a new set with is difficult to do since GC won't sell fronts and rears separately.
mike22115
Aftermarket Product Review
Apr 29, 2017 02:19 PM
Zach/90\irocZ
40
Apr 22, 2015 05:49 PM
tpidude1
Feb 26, 2010 11:42 AM
84 1LE
Apr 6, 2006 07:07 PM
nape
Feb 9, 2005 02:27 PM
