Tie rod end threads
Car: 1987 Trans Am
Tie rod end threads
I want to make some solid adjusters for the tie rods. Does anyone know the thread on the end of the tie rods? Thanks for any help.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Tie rod end threads
Make sure you have plenty of thread engagement on both sides. The replacement moog tie rods seem to be longer than OEM which can prevent you from adjusting them where you need them. Or, trim off a bit off each end rod.
Car: check
Engine: check
Transmission: check
IMHO, for street use steel would be better. If it is a drag only car then aluminum is fine.
Also, unless you have the taps and such, it may be cheaper to just purchase a set from a place such as Coleman racing.
RBob.
RBob.
GofasterFirebird
Jan 11, 2014 07:34 PM
formula forever
Feb 15, 2010 07:34 PM
CaysE
Apr 14, 2004 06:47 PM
