Need Help on Sway Bar Bushing
I thought I ordered the correct sway bar bushings for my '87 IROC but they seem to be too tall. My sway bar measures 35mm.. can someone let me know if this is correct and if not what part number I should be using? I'd like to use polyurethane of possible... Thanks!
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Engine: Lb9
Transmission: M20
Engine: Lb9
Transmission: M20
Re: Need Help on Sway Bar Bushing
Car: 1989 Firebird
Engine: 5.7 LS1
FWIW I've had the top down solution ones on my car for over a decade. The grease fitting is nice but never had to re grease them after installing them.
If I could do my entire car in poly-graphite I would, the graphite in the compound seems to cut squeaks down.
I'm curious, can you take a picture of them from a different angle? Do they fit the stock shells correctly besides being too tall?
The reason that I ask is that the stock bushings get very thin by the bushing shell in the larger sizes, and I'd probably consider making spacers to fit those if they fit the shells well otherwise.
Past that, ES, Prothane and others all have PNs that fit in the stock bushing shells. They'll also list a PN with the shell, but if you look at them the bolt holes are straight across, instead of offset like the stock ones. Some people will still just bolt them on, but that forces one side of the bushing to get mashed, typically it will cut through and you'll get steel on steel wear and binding that will break endlinks. It's easy enough to move one of the holes a little to make it line up, but no real reason to if you have the stock shells, just get the right PN from them.
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
UMI sells a bracket that allows the use of the more common straight across bolt hole bushing mounts:
http://umiperformance.com/catalog/in...oducts_id=1130
Steven6282
Mar 23, 2012 02:19 AM
vjo90RS8
Exterior Parts for Sale
Sep 10, 2007 08:49 AM
vjo90RS8
Exterior Parts Wanted
Mar 15, 2007 09:54 PM
89FormulaRoth
Nov 21, 2001 04:13 PM
