Proforged experience - have any?
Old Jun 21, 2019 | 11:42 AM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
I don't see many folks around here talking about Proforged suspension parts. On paper they look really good, a possible upgrade over other stuff like Moog/Delco. Ran across this thread, and they have Proforged a pretty good review, They like Howe better, but howe looks to be limited in what they offer and would change geometry of car.
https://www.pro-touring.com/threads/...138#post924138
Any proforgers out there?
Old Jun 21, 2019 | 11:45 AM
DaveyDug's Avatar
Car: 1989 IROC
Engine: 5.7 TPI
Axle/Gears: 2.77 Posi
Re: Proforged experience - have any?
I'm interested to hear some feedback as well, since I will be rebuilding my steering in the near future.
In another thread, some folks have indicated that Proforged idler arms do not match the OEM geometry.
Old Jun 22, 2019 | 10:03 AM
IROCZ1989's Avatar
Car: 1989 IrocZ
Engine: 421 Dart Stroker
Transmission: 4L60E Cahall Performance Built
Axle/Gears: Midwest Chassis Fab 9/ 3.55 gears
I got the whole kit. I have a complete moog setup as well. Couple of issues. First they tout the parts as coming painted. Best bet is to buy each part individual. If you buy the kit it all comes in one plastic bag. I sent it back as the parts as they were all knicked up. The its well made. I did have 2 issues with the grease fitting. Had 2 out of the set the ***** and spring were completely separated from the fitting. I'm sure it's a step above autozone stuff. At least it comes with a decent paint job and the adjusters are cnc.
Old Jun 22, 2019 | 10:32 AM
LiquidBlue's Avatar
Transmission: MD8
If that is the thread I ran across, it was moog that was mentioned: https://www.thirdgen.org/forums/susp...dler-arms.html
Old Jun 22, 2019 | 10:37 AM
LiquidBlue's Avatar
Transmission: MD8
Originally Posted by IROCZ1989
adjusters are cnc.
Proforge claims pretty much everything has CNC milled surfaces. Not sure if that is any different from Delco/Moog, but it sounds smooth and consistent.
Old Jun 22, 2019 | 10:44 AM
LiquidBlue's Avatar
Transmission: MD8
BTW - the guys in the outside thread in first post sound pretty knowledgeable, Proforge even chimes in, another owns a shop, and the rest are racing 1st/2gens. Proforge is getting pretty good reviews over there, one guy just says its good stuff, just don't compare it with Howe, not same class.
Old Jun 22, 2019 | 11:21 AM
LiquidBlue's Avatar
Transmission: MD8
Couple more great threads, one a review, another Proforged giving us some insight on the suspension industry. The insight is good, I'm in the glasses/sunglasses business, and what he says is very similar to what we experience.
Where Proforge gives us insight to their products.
https://www.chevelles.com/forums/16-...proforged.html
The review:
https://www.pro-touring.com/threads/...g-Parts-Review
Old Jun 22, 2019 | 06:05 PM
DaveyDug's Avatar
Car: 1989 IROC
Engine: 5.7 TPI
Yep, that's the one. Proforged is mentioned toward the end of the thread.
Old Jun 24, 2019 | 11:09 AM
UMI Sales's Avatar
We use Proforged in all of our street products and half the race products (our Corner Max arms use Howe lowers). Never had a problem and we abuse our stuff during racing and testing...
Old Jun 25, 2019 | 12:32 AM
SlickTrackGod's Avatar
On Probation
I second this. I have used a few Proforged products in a recent build ( s10 truck which is fairly similar in many ways to a 3rd gen) and am sold on Proforged products. very good quality. I actually changed the geometry on the truck with a custom centerlink attachment I machined which was easy to do because of Proforged nice machined mount surfaces. I could not do this with a stock piece.
Old Jun 25, 2019 | 11:36 AM
LiquidBlue's Avatar
Transmission: MD8
Thanks for chiming in. Any opinion willing to give on Proforged -vs- current day AC Delco, Moog, NAPA? I'm reading some of these main stream brands are not what they used to be. My goal for replacement parts is to try to remain true to factory because I want to preserve the car as a time capsule, but at the same time, don't want to be putting junk on the car just for the sake of looks.
Old Jun 25, 2019 | 11:37 AM
LiquidBlue's Avatar
Transmission: MD8
Nice work on that machined part! So are these are noticeably different from factory parts?
Old Jan 29, 2020 | 12:05 AM
Tidan's Avatar
Does Proforged have the incorrect idler arm height issue seen in some other aftermarket idlers?
Old Feb 6, 2020 | 12:10 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
Anyone have any experience with Proforged extended ball joints?
http://proforged.autocaredata.com/items/101-10014
Old Feb 6, 2020 | 08:30 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
I just installed the tall ball joints from pro forged ( along with the steering linkage).Ive only driven the car 3 times though, but no complaints so far.
Old Feb 6, 2020 | 10:37 PM
Lonnie P's Avatar
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
Axle/Gears: Strange 60 3.54:1
I've run them for a few years with no issues.
Old Jul 14, 2020 | 10:57 AM
91banditt2's Avatar
Engine: 5.7 HSR
84 1LE any issues with your Proforged parts?
Old Jul 14, 2020 | 11:27 AM
Tidan's Avatar
I'm in the process of installing all proforged front end. Seems like nice quality stuff so far. My new UMI a-arms come with proforged ball joints installed in them.
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
None whatsoever Bandit, steering is smooth as butter.
Old Jul 14, 2020 | 11:28 AM
Tidan's Avatar
What grease did you use?
Old Jul 14, 2020 | 12:19 PM
91banditt2's Avatar
Engine: 5.7 HSR
Are you aware of any issues with the Pro Forged Idler Arm?
Old Jul 14, 2020 | 12:20 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
I forget the name, but it's a moly lube.
I bought the idler arm too & read that thread about how the aftermarket ones are all wrong. Again I've had zero issues with mine. Even my alignment was w/out a hitch.
Old Jul 14, 2020 | 02:37 PM
Tidan's Avatar
So far I haven't seen an issue. I don't have the rest of my steering in yet so I can't say whether it will align correctly. Hoping to finish that up today.
Old Aug 1, 2020 | 10:47 AM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
I have had proforged on the front of my car two years or so now with some autox events and I dont have any complaints. Looks good works good best steering kit out there far as I can tell.
Old Oct 15, 2020 | 01:43 PM
91banditt2's Avatar
Engine: 5.7 HSR
Tidan, Got an update on the Pro Forged Idler Arm?
Old Oct 15, 2020 | 03:20 PM
Tidan's Avatar
Its been working fine. I haven't driven it a whole lot as I still need to do some body work and put the rear lights and bumper on but I don't see any problems with the idler arm. In fact I have the car back up on blocks to inspect and check torque on everything right now.
Old Jan 10, 2021 | 05:53 PM
WTR388's Avatar
Car: 87 Trans Am
Do you happen to have a part number? The one linked in this thread is for different cars, and cross comparing ball joints on rockauto shows they don't use the same lower ball joints as our cars.
Old Jan 10, 2021 | 06:21 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
101-10014 and 101-10048 are both .5" taller. Neither one shows as fitting a 3rd gen, but ive got the 48 one in my umi a-arms. I know this one is the slightly larger dia for a-arms with slightly enlarged bores. Maybe the 14 part is the standard size bore fitting. Proforged can probably verify this though.101-10049 is the OE size for 3rd gens. Also, still no issues with these parts, including the idler arm.
Old Jan 10, 2021 | 08:55 PM
91banditt2's Avatar
Engine: 5.7 HSR
For some reason Rock Auto isn’t offering Proforged for our cars anymore. Before,they did list the 101-10014 as a option
Old Jan 17, 2021 | 09:45 AM
WTR388's Avatar
Car: 87 Trans Am
I ended up ordering the 101-10048 ball joints. Everything I could read indicates they work on the S-10 lower arms, which use the same lower ball joints as us. I should have them in this the a-arms in the next week or so. Have to sand blast the a-arms because I'm in there.
Old Jan 21, 2021 | 04:23 PM
WTR388's Avatar
Car: 87 Trans Am
Just as an FYI, the 101-10048 joints fit in the stock a-arms perfectly, pressed them in today.
Old Jan 21, 2021 | 05:59 PM
Reddragon88gta's Avatar
Engine: 5.7 L98
Just saw this thread. I used proforged for new idler arm, Pittman arm and center link last summer. Really tightened up the steering and looks like quality. Came highly recommended by a good local mechanic who works mostly on muscle cars and custom cars.
itsMikey
Sep 22, 2010 05:28 PM
88fastgta
Jun 16, 2010 10:35 AM
all4u
Feb 23, 2010 07:50 PM
captbarbosa
Oct 4, 2009 06:01 PM
Avenger007
Jan 21, 2005 11:11 AM
