Front A-arm Question...
Old Oct 1, 2019 | 09:52 AM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Is there a torque spec for the bolts that connect the front control arms to the K-member?
Reason I ask is because years ago I replaced the bushings with polyurethane (I DIDN'T KNOW ANY BETTER). I never drove the car with them. I pulled the engine & trans and it sat for several years like that.
I put the new engine in a couple weeks ago and the car still sits with the front up in the air. Makes no sense. So did I get those control arm bolts too tight and they're not allowing the front suspension to settle down?...
Old Oct 1, 2019 | 10:21 AM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
Re: Front A-arm Question...
I think it just needs to settle.
Old Oct 1, 2019 | 01:15 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
It's a bit stuck from sitting. The struts can be stuck too. Move it around a little and it should settle a bit
Old Oct 22, 2019 | 11:16 PM
T.L.'s Avatar
This is ridiculous. It's been over a month and this thing has not settled one bit. I loosened the A-arm bolts and bounced it a few times, and no change. The springs appear to be seated in the upper pockets. Is it possible for struts to seize up and refuse to compress after sitting fully extended for 17 years?...
Old Oct 23, 2019 | 09:26 AM
885speed's Avatar
Car: 1988 Camaro
Engine: LR4
Axle/Gears: 3.23posi/disc
Yes, struts can seize up. But in your scenario I don't think that's the case, especially if there is give in the suspension when you push down on the car.
Has the car rolled at all? If not roll the car back and fourth a foot or two and it should settle. Just bouncing the car won't really do much..
One last thing, is the engine that went in the same one that came out?
Old Oct 23, 2019 | 10:43 AM
Engine: 350 TPI L98
Transmission: WC T5
Yeah, important clarification- is the car being driven or just sitting ? If it just sitting it isn't going to settle. "Settling" happens when the car is driven and the suspension is exercised. I doubt much will happen if the car isn't moving.
Old Oct 23, 2019 | 12:11 PM
T.L.'s Avatar
Yeah, just sitting right now Still need to get everything back together and break in the cam...
Old Oct 23, 2019 | 12:21 PM
Engine: 350 TPI L98
Transmission: WC T5
There's the prob. Gotta drive it!
Old Oct 23, 2019 | 12:32 PM
T.L.'s Avatar
Just never experienced this before. I did an engine swap in an old Ford about 12 years ago and it didn't do this. Of course it sat for 9 months with no engine, not 17 years...
Old Oct 23, 2019 | 01:03 PM
gt4373's Avatar
Transmission: 5-Speed Manual
Old Oct 23, 2019 | 01:46 PM
427seven's Avatar
Car: 1989 Firebird GTA
Engine: Motown Aluminum 427
Transmission: TH400/GVO
New engine? same as before? Any other diet items, Aluminum heads etc? When you bounced it, were you able to move it up and down like you did before? If all you changed was the a arm bushings, and it still moves up and down when you bounce it, it should drop back down after a couple hundred miles. Shocks don't usually gain pressure by themselves... If they've been sitting forever, you might have lost pressure, but only gained if gas was added somehow or there was a net reduction in space inside the gas chamber(like happens when the shock is compressed), the pressure couldn't have increased.
Old Oct 23, 2019 | 02:17 PM
T.L.'s Avatar
Iron-headed 350, so no weight reduction there. I figure it's about 150 pounds light right now as there is no alt, P/S pump, A/C compressor, radiator, condenser, or hood installed yet. No AIR pump either but I'm ditching that.
But when I put my full weight on the car. It moves a quarter inch or less. . There's like 5 or 6 inches of space between the wheel arch and the top of the tire.. Guess I'll just have to get it all back together and drive it. Don't know what else to do..
Old Oct 24, 2019 | 07:52 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
When I swapped the engine in my car the front end was still sitting high even with the engine and trans sitting in the car fully dressed. kind of just forgot about it and it solved itself after I moved it in and out of the garage a couple times.
Old Oct 24, 2019 | 09:08 PM
T.L.'s Avatar
Thanks. That is encouraging...
jczoka
Jan 25, 2018 11:18 PM
zride91
May 7, 2008 06:50 AM
Hoosier Bob
Jul 20, 2005 02:53 PM
KagA152
Feb 7, 2004 10:38 AM
Idlehands
Mar 11, 2003 03:22 AM
