WTF backfiring and catching fire after intake reinstall
Old May 13, 2002 | 05:26 PM
TBI305Camaro's Avatar
i reinstalled the intake and now the car wont start it will crank backfire and it put into flood clear mod it will catch fire. i had the distributer out so i guess it went way out of time...maybe i didnt put it back the same...still ive messed with it and it wont start...could the parts cleaner and carb cleaner i used all over the TBI cause this? whats up with it?
::edit:: also the CTS broke while i had the manifold off but the metal terminals are still there and it still plugs in pretty much the same as it normally would...would the CTS cause it not to start? somethings not right here because usually the car will start even if the timings kinda messed up...ive turned it and turned the distributer same thing everytime crank crank puff...if you give it throttle fire will shoot out so yeah it must be getting spark somewhere
Old May 13, 2002 | 05:46 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
reinstalled? why?
Old May 13, 2002 | 05:48 PM
its been leaking oil for awhile and i was tired of it. lately its been leaking 2 quarts every 4-5 days so....it was leaking off the back of the intake so i wanted to fix it...didnt have the money for a new manifold just yet either.
Old May 13, 2002 | 06:11 PM
Snowdog 91 Formula's Avatar
Owwwwwwwwww!
Owch! Is this the stock TBI unit? I'm wondering if you have a fuel leak on the back side of your manifold.... I still can't see how the IAC would be damaged/affected unless it were deliberately torn off for some reason...
You are flooding the manifold, that is for sure.... I have the suspicion that your throttle body is leaking directly into the intake, or you have a bad fuel line.
I would say since the IAC was damaged, you might have possibly damaged the fuel line in the throttle body itself....
OW!
Old May 13, 2002 | 06:31 PM
JokerRS's Avatar
Car: 92RS
Engine: 357
If your dist is not installed correctly it could backfire and catch on fire simply because its firing while the intake valves are open.
Old May 13, 2002 | 08:43 PM
IAC isnt damaged the coolant temp sensor on the manifold itself is...i could be leaking fuel i took the injector pod off then went ahead and put it right back on i dont think the gasket was bad or anything i tightened it down pretty good...im thinking maybe its just severly out of time...i installed the distributer about the way it came out i dont get it...
i have a light i just need to get it to start so i can get the timing right. is the TBI leaking? or you just think its the timing? maybe if i disconnect the EST and try messing with it
Old May 13, 2002 | 11:32 PM
91_hd's Avatar
The CTS should be ok if its still making a connection. Your timing is way off. Did you mark the distributor when you pulled it? Do you know how to find TDC by turning the crank?
Old May 13, 2002 | 11:53 PM
i didnt mark it but i know where it should be around from memory. ill take the cap off tomorrow and see where the button is pointing..i have no idea about the TDC? ill mess with the timing some im pretty sure thats it...i just hope i fixed the oil leak and its not worse now or something that would suck
Old May 13, 2002 | 11:58 PM
91_hd's Avatar
It sounds like your off by a tooth or 2. Keep us posted.
Old May 14, 2002 | 12:07 AM
soon as i wake up in the morning im gonna go out and mess with it im sure i can get it going...i had the distributer apart once and when i put it back in it didnt do this....
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
dyeager535
Aug 28, 2015 08:10 AM
theshackle
Aug 22, 2015 06:52 PM
86White_T/A305
Aug 17, 2015 12:16 AM
