Open element a must for these cars!
Old Jul 9, 2002 | 08:05 AM
Jokerman's Avatar
Engine: slowtacular L03 305
Transmission: slushem 700r4
*** damn i can't believe the differance in sound and crisper throttle response. (probably froma new filter, but oh well) Deffinantly go get one if you haven't. I managed to a nice crome edlebrok with filter for $21.23 or so and it took about 10minutes to get on (several test closeings of the hood). Very easy and sounds very good.
Old Jul 9, 2002 | 10:05 AM
FAST85Z28's Avatar
yea that was one of the first things I bought.. I really didn't care if made a big difference.. It just looks a lot better when ya pop the hood (doesn't looks so old, my opinion). and now that i do have it and everything you can hear it suckin once in awhile when im not lazy and go clean it.. sounds much better..
K&N once again made a differnce for me!
Old Jul 9, 2002 | 10:47 AM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Old Jul 9, 2002 | 10:48 AM
i have an open element too, a 5.5"x1.5"
Old Jul 9, 2002 | 04:35 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
I have a dual snorkel. Chromed it before install.
Looks good, sounds good and definitely more throttle response.
http://albums.photo.epson.com/j/View...p=60913525&f=0
Old Jul 9, 2002 | 05:23 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
sounds good boys, how many of you needed/check out my article first?
by the way, fast85, actually it makes it look OLDER, but... thats why it looks cooler, it looks presmogg era.
i will second the idea that if you do ever do anything to your car, this should be the first thing, and, if you do only one MOD ever. do this one.
Old Jul 9, 2002 | 05:43 PM
2birds's Avatar
Looking cool is good and all but.... It seems to me that cool air is better than all that hot air under the hood. Granted the air intake trac from stock is crappy, but with some work and little $ you can get the air from outside the hot engine bay. Just my 2cents.
Old Jul 9, 2002 | 07:00 PM
Jokerman's Avatar
well since i have never owned a smoged efi car before i read it a couple of times just to make sure, but once i did i realized that with the exception of the little sensor i would have know how to do all of the rest pretty easily. The pictures by the way help alot more than the words did at times.
Old Jul 9, 2002 | 08:20 PM
open elements work just fine and are way simpler, which is what most people want in their engine bays. also open elements can benifit from cowl inductions hoods
Old Jul 9, 2002 | 10:46 PM
snflupigus's Avatar
show me proof that cool air makes an "i-give-a-sh$%" difference in an lo3 and i will bow to all the cold air induction guys. sorry, my research and reading show only as much as a few tiny percent difference - equallying like 2-5hp tops.
so go for cold air induction, or go cheap and just as good open el.
Old Jul 9, 2002 | 10:57 PM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
I got one 'cause it looks cool (Edelbrock and K&N). I didn't notice a difference in throttle responce or sound.
Old Jul 9, 2002 | 10:59 PM
no way
Old Jul 10, 2002 | 12:22 AM
RSFreak's Avatar
Originally posted by brodyscamaro
no way
Way!
I got the open element right after I bought the car, so I hadn't had time to get used to it with the stock air cleaner yet. Plus I still had my '85 Z28 at the time and was driving it most of the time.
Old Jul 10, 2002 | 06:25 AM
Joel Geerling's Avatar
Car: 91 Formula
Engine: 305 TBI
Re: Open element a must for these cars!
Originally posted by Jokerman
[BI managed to a nice crome edlebrok with filter for $21.23 or so [/B]
You sure it wasn't $21.24? or $21.22? j/k
For those lauding cold air vs. open element, why not go for the best of both worlds: cold air into an open element (via ram air, regular cowl, or Formula cowl hood)? I plan on doing this someday, when I have free time to mess with things again. I think it will make the engine compartment look less attractive, tho, what with the stuff I'll have to lump around the air cleaner to direct cold air to it.
Old Jul 11, 2002 | 03:01 AM
Mr300's Avatar
can someone tell me which gives better performance, open element or dual snorkel?
hey joel, i live in st. louis too, and i was wondering if you ever go to Gateway Raceway? i'm there every friday night. (sorry if this is off topic)
Old Jul 11, 2002 | 08:32 AM
snflupigus's Avatar
they are equal. equal enough to decide based soley on what you want it to LOOK like.
cold air induction is good, but with the way most dual snorkel designs, ribbed hoses etc are used which slow flow giving the air time to heat up a bit. the best one ive seen is the ram air box. it is essentially an open element with 4" hoses as the snorkels. Best of both worlds, but $.
its the same principle of the new intake designs, airgap or standard. The air gap manifolds are good for about 3-5% increase in power. On an lo3, thats like 6 horse. so take your 5% and then subtract a 20% loss for power at the wheels and you see how much its worth. You could get more power by converting completely redline or another brand of synthetic fluids. ($150 though).
Old Jul 12, 2002 | 01:33 AM
Mr300's Avatar
does converting to open element make your car sometimes not pass emissions? about how long does it take to do it?
Old Jul 12, 2002 | 01:47 AM
Car: 91 Formula
Engine: 305 TBI
Nope - shouldn't (unless your car already has serious emissions issues). Took me maybe 2 hours (had to drill out a pre-embossed hole in the open element for the IAT sensor).
Old Jul 13, 2002 | 05:05 PM
88Bravo's Avatar
Car: 1988 Pontiac Firebird, flat black
Engine: Stock 305 LO3
Transmission: Five speed
A buddy of mine had a air cleaner top that fit the top of my air filter an in an essence gave me an open air cleaner. When I was driving it gained in pick up and sound, but when I was just cruising around the car was jerky. It felt like the mixture was wrong, to lean. Any thought about this? LO3 motor. I want to go open but I cruise around more than I hotrod.
Old Jul 14, 2002 | 06:08 PM
Jokerman's Avatar
That may be a sign of something else since i have no problems running around under normal conditions.
Old Jul 16, 2002 | 01:41 AM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
Just a quick comment. My car ran consistantly faster with the stock air cleaner on than with not one on at all. You would think that it would be opposite.
Old Jul 16, 2002 | 07:06 AM
Car: 91 Formula
Engine: 305 TBI
Could it be because no functioning IAT w/o the aircleaner? I know it throws a code this way, even just idling, but I never drove it.
Frozer!!!
Jan 19, 2024 04:55 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
Linson
Aug 21, 2015 02:12 PM
