where should my stock engine redline and shift?
Old Aug 29, 2002 | 11:42 PM
burnouts4ever's Avatar
I have a 91 rs camaro with a v8 in it, auto, now does this sound normal i am going on highway and if i floor it going like 60 and continue florroing it will continue to redline until i let off the gas, I am saying it will keep going to say 6500 rpm and then i get scared its gonna blow up and get off the gas when the car is in overdrive, in drive i dont have this problem as much
Old Aug 30, 2002 | 01:29 AM
vrooom305's Avatar
In my *opinion* I think it's supposed to be around 4500RPM but then again I have 3.05 nonposi diff. So I could be wrong.
Old Aug 30, 2002 | 02:51 AM
scott92RS's Avatar
Car: 92 Firebird
Engine: 350 TBI/LT4 cam
Transmission: 700R
Dude I'm lucky if I get passed 4k RPMs.
Old Aug 30, 2002 | 10:11 AM
so what does the problem sound like?
Old Aug 30, 2002 | 04:11 PM
vrooom305's Avatar
There might be something wrong with the tranny or the tach may just be inaccurate.
Old Aug 30, 2002 | 09:49 PM
my 1st-2nd and 2nd-3rd shift where they are supposed to but my 3rd-4th is it out of adjustmen?
Old Aug 31, 2002 | 03:30 PM
alright 1st-2nd is pretty good, its 2nd-3rd which is around 60 mph that my car is having problems with? is just maybe my 2nd-3rd and maybe 3rd-4th bad??? i have an auto. or is 60 3rd-4th shift?
Old Aug 31, 2002 | 06:17 PM
Slade1's Avatar
In 3rd a stock lo3 barely has enough power to goto 4500 rpm...
In 2nd you can bring it to 6000 rpm with no prob though, but at that rpm you're gaining very little in the acceleration department...
Are you taking about crusing at 60 in 3rd gear then flooring it to WOT and it downshifts to 2nd and pulls to 6500??
In that scenario it should shift when it hits 4500 rpm in either 1st or 2nd at WOT in stock form. Your tv cable is probably out of alignment. It's an easy adjustment, I think there's a guide somewhere on site for it.
As for shift points:
At WOT in 3rd Gear (D)
1-2 4500 RPM
2-3 4500 RPM
At WOT in 4th Gear (Overdrive)
1-2 4500 RPM
2-3 4500 RPM
3-4 <2/3 Throttle
There's a kickdown valve preventing 3-4 shift at wot.
At part throttle you can really have it shift whenever you want to, but as a rule of thumb for good shift points you want it that at minimum throttle you can force a 1-2 shift, but if you go WOT it'll automatically downshift to first again.
Old Aug 31, 2002 | 07:10 PM
Yes that is what i am talking about!!
Old Aug 31, 2002 | 07:14 PM
so 4th gear is overdrive?
Old Aug 31, 2002 | 11:44 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
The stock gear ratios are....
1st gear.... 3.06:1
2nd......... 1.63:1
3rd......... 1.00:1
4th......... 0.70:1
So yes, 4th gear is an overdrive gear.
The above gear ratios are input shaft:drive shaft ratios. In 1st the engine (not counting torque converter slippage, but that's a whole other topic) is spinning 3.06 times for every 1 spin of the driveshaft etc.
Once you're in 4th gear the engine's only spinning .70 (or close to 3/4 turn) times every time the driveshaft spins once. This helps cut down on engine wear and increase MPG.
If you have the gear selector in OD and you're going 60 MPH, then you floor it your trans is going from 4th back down to 3rd, or it should be. If it's going back down to 2nd then (as said earlier) you need to adjust your TV cable. And if it's holding 2nd until 6500 RPM, then you've got other issues that need to be posted in the Transmission/Driveline board.
If it is only going down to 3rd gear then it will rev to 6500 RPM because (as mentioned earlier again) the trans is set up that way. If you go past 2/3 throttle, the trans will not go into OD unless you modify it. The poor little engine will rev its ***** off until it 1. blows up or 2. you manage to hit the speed govenor which is set at ~110 MPH from the factory.
AJ
Old Sep 8, 2002 | 08:01 PM
so are u guys trying to tell me u cant have it floored down the whole quarter mile?
Old Sep 8, 2002 | 08:35 PM
Jokerman's Avatar
Engine: slowtacular L03 305
Transmission: slushem 700r4
3rd gear on the lo3 cars with the 700r is good for the 110mph limiter (bounced off it a couple times) with out winding out to some ungodly rpm. If you have had some custome prom work and removed it then you may be able to get up a bit more speed, but considering how much the power is starting to drop off at that point its not likely you will make more than 120.
Old Sep 8, 2002 | 09:10 PM
you see the problem is i can floor it upto 60 and then from 60 on if its floored i will accelerate but my rpm will keep on going and going till i let off the gas and engine will make a sound like its relieved i let off and shift so i just want to know what is the problem here?
Old Sep 11, 2002 | 02:09 PM
turtle's Avatar
try the gov in the trans. mine will do the same thing, bad gov. my iroc is suposed to shift at 5250 roughly WOT and will rev to 6500 in any gear if i dont let off. dana (probuilt) said look at the gov. bought it just need to install it.
Azrael91966669
25
Jun 20, 2017 04:04 AM
italiano67
Dec 11, 2016 09:21 AM
InfinityShade
Aug 22, 2015 08:00 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
dhonda200
Aug 11, 2015 11:50 PM
