does ANYONE make good heads for the 92 ??
ok i called edelbrock, they said they didnt have ANY type of heads or a cam for the 92 rs, wtf, ...does anyone make them?? if so who?
92 rs 305 tbi
92 rs 305 tbi
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
World Products S/R 305 Torquers. Direct bolt on replacements.
They sell them at jegs. check there website www.jegs.com i think
you can run any head you want on a 305. the problem is that most companies do not test their products on 305's. i used edelbrock heads on my car adn i was very happy with them. teh only heads i know you are liekly to run into trouble with are teh trick flows.
the world products torquers are a great head for the price. teh casting is very good adn they have a 58cc combustion chamber just liek stock so your compression will stay the same.
later
tim
later
tim
gotta watch out for clearance issues...i dont thing u can run 2.02/1.6 on the 305s...1.94/1.5 i think thats all u can run...S/Rs are good for the 305...since they are made for the 305....now...if u had a 350 thats a different story....
Personally i like the Sportsman IIs...but..they are 2.02/1.6s
DABE
DABE
i ran the 2.02/1.60's in my car. it is fine. nothing hits anywhere.
what you can get if you go with too much lift is an interferance to teh air flow aroudn teh valve called shrouding. that is where there is nto enough space aroudn teh vavle for he air to eb drawn past it properly. it creates turbulance adn low air velocities.
with a fairly mild cam liek a LT1 or LT4 the larger valves will work very nicely.
later
tim
later
tim
everyone agree on the torquers? cool deal.....do i have to modify anything else with that or just bolt em right on and go...also, what would be a good cam to go with that??? i plan on buying the cam and the heads at the same time so tell me what yall think:hail: :hail:
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
The LT1 cam/SR Torquers is a proven combo, add the Edelbrock TBI intake and you got yourself a pretty stout ride. I took the road less traveled though
Car: '02 Rodeo
Engine: 3.2 V6 DOHC
Transmission: 5spd
Axle/Gears: 4.30 Dana 44 Rear 10 bolt front
how about the lt4 hot cam and some 1.6 rockers to go with that?
what do you think about that combo?
lol yall theorize and tell me the conclusion ..keep in mind i want to keep it *fairly* simple....im not exactly an experianced mechanic with years of training and a whole garage of tools backing it heheh
what do you consider simple?
a cam, head, and intake combo that will be easy to tune and not cost very much is a factory LT1 cam, edelbrock performer tbi intake, and world products torquer 305 heads.
as far as how easy it is to do, the mechanical stuff is straight forward enough, just takes time. teh hard part is afterward when it is tiem to tune everything.
the best bet there is to get a hold of a laptop and a copy of win aldl. that way you can get a data log going of the car and see what adjsutments it wants/needs. it can also be used as the basis for a true custom chip, which you will need to get teh most out fo yoru new combo. check out the tech articles about getting started in burnign chips to see how.
later
tim
later
tim
yeah i figured the tuning part was gonna be difficult....can i just slap a custom prom in it, and tell them everything ive done and they burn it, and it be done with?? or do i have to do it myself ??
teh best place to start seems to be with a cop car chip or somethign similar. what you can get from telling people what is in the engien is only a starting point. if you want all teh power, you need to do all teh work. that menas burn then data log then burn again and so on.
later
tim
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
eh...what do i need t program my own prog, ..a programmable chip/ecm or what
This is about the cheapest chip burner available: http://www.ustr.net/epromer5/index.shtml
Then you can use WINBIN or TUNERCAT to edit your chip and the burn it to a new prom and begin testing away.
i seriously have no idea how to do that, . where do i get a programmable prom?? or can i use the one i have now? if i do somthing wrong can i re-write the prom or do i have to buy a new one? sorry for all the questions, but i just wanna know what to do before i mess somthing up.....should i get the prom and prom writter *first* then get the heads and cam and intake?
Car: check
Engine: check
Transmission: check
now i see why people switch to a carb and toss the damn ecm....bleh
RBob.
ah flashback to my 600 ....good call, ...guss its time to start learning.....and shelling out 250 bucks for a scanner , a programmer, and a re-writeable prom...then 200 more for software :\
slowmaro, you don';t need a ton of stuff to start burnign chips anymore. the win aldl software is free, almost any old laptop will do the trick, and you can make the patch cable you need from radio shack parts for around $7. the only thing that costs is the burner itself adn i don't even think they are very expensive.
there are also a ton of resources to give you a basis to start your own custom programming.
just like RBob i grew up playin with carbs, and i actually got well into college before i saw the real benefits on fuel injection. when you use mechanical methods, you get mechanical results, when you use an ecm you have teh unlimited tunability of digital for both fuel and spark.
later
tim
later
tim
Linson
Aug 21, 2015 02:12 PM
db057
Aug 11, 2015 10:11 PM
