TBI spacer hood clearance
Car: 91 RS Camaro
Engine: 305 TBI
I have a TBI one inch spacer but I am worried if it will fit with no hood clearance probs. I have the stock intake and air cleaner but I can see an indent of the air cleaner in the insulation when I close the hood. Does anyone know if this will fit or not. Don't want to do all that work and then have to take it off.
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
i have a 1/2" spacer, with a 14x3 open element, and that just clears the stock hood on a my camaro. if you got like a 2 1/2" filter, it should clear with a 1" spacer.
(or you can use this as a good exuse to get get kewl cowl hood
put the spacer on, try to close the hood, and then tell the wife you need to get a new hood
) Thread Starter
Car: 91 RS Camaro
Engine: 305 TBI
LOL that is a good idea but I already have her primed on getting a new cowl hood with the taxes, but that is months away
. I just wanted to get this thing on and see if it does anything.
. I just wanted to get this thing on and see if it does anything. Supreme Member
Car: 1990 Camaro RS
i would really have to get out the stock assimbly and actualy measure it for you to find out it it would fit with a 1" spacer. IIRC the factory setup sat lower that my OE with a 3" filter. so it is possible that it might just squize in there. Supreme Member
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
i know an edelbrock tbi intake and a 1 inch spacer with the stock air cleaner assembly WONT work.. with a stock rs hood. my brother and i tried onr night. the hood closes but it bend the back part up a bit
Car: 2002 TT Corvette
Engine: 5.7L
oh... u might have to cut down the stud the air cleaner wing nut is on because that will hit the hood with u close it. I have a pic of the 1" spacer on my car.
this was before i figured the stock manifold/heads were **** and changed them. The car blew up though ... RIP. email me if u got any questions. camaroguy72@aol.com . later
Rob
Rob
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
kah992
Aug 19, 2015 02:55 PM
