Pass side valve cover
Old Mar 9, 2003 | 08:43 PM
MericanMuscle's Avatar
Well i was trying to put on my elite series valve covers and it looks to be pretty interesting on the passenger side. I cant even see the damn valve cover. Now i know you can delete or relocate the heater valve, but im not sure how.. i searched but didnt find anything explained clear enough for me.. There are two screws holding the thing down and like 3 or 4 hoses going into it.. one goes to the manifold i believe, one to the heater core, and one to the air tubes on the exhaust manifold. Now how do i clean this all up.. so i can get that valvecover on
oh yea this is on a 89 Lo3
Old Mar 9, 2003 | 08:53 PM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
Just take the screws out so the hoses are loose and undo the one going to the radiator. then you can bend the hoses back and hook them toward the windshield with something while you work on the valve cover.
Old Mar 11, 2003 | 10:05 AM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
http://www.geocities.com/tzfbird/Valve.html
Hope that helps ya out.. pics and all.
If you keep looking around on my site, you can find some other pics of what it looks like finished from a distance.
http://www.geocities.com/tzfbird/tzfbird.html
Old Mar 11, 2003 | 11:35 AM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
I just deleted the damn thing. I dont know what the pitfalls of it were, but I ran a line from the intake to the heater core, then the heatercore to the radiator. Then I plugged that vac line and everything seems to be OK.
Old Mar 11, 2003 | 11:37 AM
camaro89rs355's Avatar
Car: 89 Camaro RS
Engine: 355 TBI
what is the heater vavle for anyway i want to get rid of mine if i can so i can have more room
Old Mar 11, 2003 | 12:29 PM
Thanks for the info, well see how it turns out
Old Mar 14, 2003 | 07:33 AM
CamaroGuy71's Avatar
Car: 2002 TT Corvette
Engine: 5.7L
the beater valve is like the meeting point for coolant between ur heater pipe, core, and intake manifold... if u dont use heat u can eliminate it. or...on the older cars. they run a hose from the water pump to the core... i guess u can do that? Or u can just cut the hoses shorter to move it towards the back of the firewall to get it out of the way.
Old Mar 14, 2003 | 10:12 AM
vjo90RS8's Avatar
Car: 2002 Z28
i deleted mine, i just ran a hose from the water pump to the heater core and from the heater core to the back of the valve cover. that simple. You will have to buy some hose clamps, hose, teflon tape, and 1/2" and 5/8" thread to barb fittings for the intake and water pump.
Old Mar 14, 2003 | 07:52 PM
Alright i know what im doing when it comes to relocating the diverter..? valve now.. but what is that black box near the front of the pass side valve cover and can it be deleted or relocated as well? It has a metal pipe coming from the radiator to the bottom of it and like 3 or 4 hoses as well.
Old Mar 15, 2003 | 10:56 AM
1MEAN92RS's Avatar
Car: '92 Rally Sport
Engine: LO3
Or you can always use one of these... I did, and it works great.
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
1985chevydude
Aug 20, 2015 12:29 AM
wruiz
Aug 11, 2015 02:59 PM
mustangman65_79
Aug 8, 2015 01:18 AM
