smells like gas
Old Aug 12, 2003 | 10:52 PM
2kickassbirds's Avatar
Car: 1991 firebird formula
Engine: 5.8
smells like gas
I have a 89 formula with a 305 tbi with a 5 speed when I get out the car it smells like gas.
Old Aug 12, 2003 | 11:00 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
Hmmm. Thank you for the info on your car.
Old Aug 12, 2003 | 11:03 PM
Engine: LO3;383tpi
Smart @$$ aside, what part of the car is the smell coming from, engine, gas tank, etc.? It could be anything from a dirty fuel injector spraying fuel into the air cleaner, to a leak or a busted fuel line, to a tank problem.
Old Aug 13, 2003 | 07:49 PM
pat12spe's Avatar
I have the same problem. My gas cap is all screwed up and most retards around here working at gas stations don't check to make sure they put the cap on right. I usually drive for about a minute down the road with the windows down and i can smell the gas. I just pull over and yank on the cap and it pops right off. Then I put it on right myself.
Old Aug 13, 2003 | 09:58 PM
Engine: LO3;383tpi
Two Words.... SELF SERVICE. If you know it's going to happen then do it right and do it yourself.
Old Aug 14, 2003 | 03:04 AM
pat12spe's Avatar
There is no self serve in NJ. It's all full service if you even wanna call it that.
Old Aug 14, 2003 | 04:23 PM
Engine: LO3;383tpi
Wow! That sucks. Sorry about the disrespect. I was thinking there was self service there too, and it just didn't make sense. Maybe thowing in a complaint would help?
Old Aug 14, 2003 | 07:27 PM
Engine: 5.8
the car smells around the back.
Old Aug 15, 2003 | 09:51 AM
Engine: 5.8
and i've changed the gas cap.
Old Aug 15, 2003 | 09:55 AM
swerve-driver's Avatar
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
Recall?
My 1991 RS was recalled about 6 years ago due to pin holes in the gas tank. Could this be you, too?
Or, you may have leaking fuel lines. Did you try putting some cardboard down underneath your car overnite and seeing if there are any tell-tale spots?
Hope you are able to determine the cause-
S-D
"Hmmm. Thank you for the info on your car."
I'm still laughing about that.
Old Aug 15, 2003 | 09:51 PM
Engine: LO3;383tpi
What swerve said.
I know my sending unit wasn't in the best shape when we pulled it for the pump installation. Probably do to that fact that the lines are routed in an area bound to trap moisture. It could be your problem. Could be the fittings on the filter as well
Old Aug 24, 2003 | 01:56 PM
Engine: 5.8
There are no recalls in 89.
Dwayne614
Sep 29, 2015 11:05 PM
Racerx974
Sep 19, 2015 10:16 AM
earlpote
Sep 12, 2015 11:55 AM
Glowsock
Sep 11, 2015 11:09 PM
