hey some info on a torque converter
Old Aug 14, 2003 | 10:40 AM
miacamaro305's Avatar
Car: 89 Camaro RS
Engine: 5.0 tbi
Transmission: street-strip 700R4
well guys whats a good stall converter for my camaro when i put a lt1 cam and manifold and the rest of my mods in my sig?
also my buddie has a 450 hp 383 engine whats a good converter for him on a th-400?
Old Aug 14, 2003 | 04:46 PM
JPrevost's Avatar
Car: 91 Red Sled
It all depends on the cam your buddy is running but for you, something with 2000rpm stall would work nicely as a daily driver. Anything more and not exceeding 2600rpm would also work just make certain you get a locking converter to save $$$ in gas each year.
Old Aug 15, 2003 | 07:54 AM
Car: 89 Camaro RS
Engine: 5.0 tbi
well whats the diffence betwen a locking converter and a non locking one?is a 2400 stall great or perfect
Old Aug 15, 2003 | 11:27 AM
vjo90RS8's Avatar
Car: 2002 Z28
my car is a daily driver and ill be going with a ACT 2400 stall and Pro Built Street/Strip tranny this summer.
Old Aug 15, 2003 | 12:03 PM
bigREd car's Avatar
Car: camaro
Engine: mighty 305
Transmission: mighty 700r
get a s10 v6 or i4 stall converter that'll stall you around 2400 of course it depends on your hp... some of the other guys will know more on that then i will..
Old Aug 15, 2003 | 12:38 PM
jpk91rs's Avatar
Car: 91 RS, 00 TA Ram Air, 86 IROC
Engine: 305 tbi, LS1, 355
Transmission: 700R4, 4L60E, 700R4 NonLU
the best place to find the perfect stall convertor for yourself and your buddy is with the convertor manufacturer. Whether that be TCI, B&M, or whoever else you might want. That is my $.02.
Old Aug 15, 2003 | 02:15 PM
25THRSS's Avatar
Basically you want to launch at your peak torque and in order to find out exactly where that is you need to dyno it to find out the perfect stall for you. If your car is a daily driver and yuor torque peaks at like 5,000, which yours will not, you don;t want to go that. I wouldn't go any higher than a 3500, but thats pushing it.
Old Aug 16, 2003 | 01:35 PM
Car: 89 Camaro RS
Engine: 5.0 tbi
well my car doesnt have much mods done to it so were ever the torque is at stock specs thats the stall i need right
Old Aug 16, 2003 | 06:36 PM
25THRSS's Avatar
pretty much. Your power band shouldn't have moved around that much. A 2400 stall would work nicely.
Old Aug 17, 2003 | 08:05 AM
Car: 89 Camaro RS
Engine: 5.0 tbi
whats a good converter company and which 2400 stall do i need for my daily driver a locking or a non locking and what ets improvemnt will i see?
Old Aug 17, 2003 | 11:18 AM
25THRSS's Avatar
You want a locking converter. I run a vigilante, but they are pricey. Check out ACT.
1992 Trans Am
May 10, 2023 07:19 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
jklein337
Sep 19, 2018 06:23 PM
xxx3man`
Sep 23, 2015 10:37 PM
gwade12
Aug 8, 2015 08:17 AM
