lo5 heads, compression and cc?
Old Sep 11, 2003 | 02:25 AM
TKD89RS's Avatar
Car: 1995
Engine: 5.7
what is the compression and cc on lo5 heads? seems there is a debate on this. i have the lo5 out of the caprice, fleetwood, roadmaster. vin 7 92-93
Old Sep 12, 2003 | 01:11 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Both Dyno Don and I (as well as others whom I don't recall names of) have measured the intake runners at 168 cc's.
We've also verified the combustion chambers being 64 cc's.
These are on the 14102191's and 193's.
Do a search under Dyno Don's name for "swirl port". You should find a wealth of info.
Old Sep 12, 2003 | 12:23 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
According to paceparts they are 64cc and have 9.6:1 compression. At least on the motor I have. It is a caprice motor also. I'm about to ditch the boat anchors sitting ontop of my block for a set of vortecs anyways.
Old Sep 12, 2003 | 01:57 PM
TKD89RS's Avatar
Car: 1995
Engine: 5.7
thanks guys, im goin to get the vortec kit from SDPC2000.com. they have a great deal on them.
Old Sep 13, 2003 | 12:39 AM
Transmission: 4l60e
I calculated up the total cost and that vortec kit isn't that good of a deal. You can get everything separate for cheaper. Go to jegs and get a price on everything. I think its cheaper to get everything alone. Not as easy but cheaper.
Old Sep 13, 2003 | 01:40 AM
TKD89RS's Avatar
Car: 1995
Engine: 5.7
really, that kit came with heads with the upgraded springs, intake, gaskets, and bolts i dont think its cheaper to get them separate. and can u even get vortec heads separate with teh springs. from them u can.
Old Sep 14, 2003 | 07:40 PM
TKD89RS's Avatar
Car: 1995
Engine: 5.7
acuallly im goin with the world sportmans. maybe port them.
Old Sep 14, 2003 | 09:35 PM
Transmission: 4l60e
I was going to get Sportsman II's. Then I ran into a set of Vortecs for cheap so I'm just gonna go that route. Maybe port them someday yadda yadda yadda. Right now I'm gonna keep the car fairly mild since its my only car. And because it snows here. And gas is getting ridiculous.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
92projectcamaro
Jan 18, 2016 08:00 AM
New2Chevy
Sep 28, 2015 12:35 AM
z28guy134
Sep 1, 2015 11:50 PM
