how hard will it be to swap?
Old Dec 14, 2003 | 10:46 AM
miacamaro305's Avatar
Car: 89 Camaro RS
Engine: 5.0 tbi
Transmission: street-strip 700R4
hey i know that our tbi flow very lil like less then 500 cfms so i was wondering how hard it will be to swap a carb in besides swap a manifold?and what hp gain will i see from a edelbrock performer and a 600 cfm carb?like 30 hp right?what will i do with the oem wires that run to the tbi?hide or burn a custom chip so the computer realises a tbi isnt there?
Old Dec 14, 2003 | 10:55 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
There is a tech article on this. I would start there. It pretty muched tells you what you need to do. I cannot remeber all of the details off hand.
Old Dec 14, 2003 | 11:02 AM
Car: 89 Camaro RS
Engine: 5.0 tbi
i look at it ,and its alot of things i think i stick with the holley 670 cfm
Old Dec 14, 2003 | 02:17 PM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
I'd say do some other things before you get the Holley 670. You don't really need it just yet, I don't think. I'd say once you swap in a cam and intake then do the Holley 670.
Old Dec 14, 2003 | 02:54 PM
Car: 89 Camaro RS
Engine: 5.0 tbi
well im going to send my 5.0 tpi heads to get freshen up and rebuilt and bolt those on my lo3 tbi and a edelbrock performer manifold maybe 1.6 rr and lt1 cam not sure
Old Dec 14, 2003 | 03:34 PM
BronYrAur's Avatar
Engine: 305 TBI
Better get ready for some computer tuning too then if you want it to run right. That could be a good setup with the proper tune.
Old Dec 17, 2003 | 06:17 AM
Car: 89 Camaro RS
Engine: 5.0 tbi
i have a guy like 45 min away that will take care of that part for me im doing it all by febuary
Old Dec 17, 2003 | 10:47 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Id recommend getting the prom burning equipment and doing it yourself. If your smart enough to post on this message board, then your smart enough to burn proms. The quality of the bin on the proms, though, is entirely up to your tuning abilities. Its certanly possible to use a computer to do jsut the timing but again, if you dont have the ability to adjust the computers timing curve then youll be held back by the stock timing. If that be the case, then you shoudl probably get a non-cc HEI dist. Depending on the present tuning of the car you could have big gains with a carb. If the stock tuning is way off, then a properly tuned carb will make a big difference. If the tuning is relativly close to what the car needs, then you probably wont notice too much gain over, say, a holley or BB tbi unit.
bamaboy0323
Sep 3, 2015 06:07 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
86White_T/A305
Aug 17, 2015 12:16 AM
cstrobel65
Aug 15, 2015 10:19 AM
