Timing question with photo, is this 2* advanced?
Car: Gutted 92' RS TRACK ONLY / '86 Mustang gt 'vert / 1982 Yamiaha xs400 Cafe Racer
Engine: L03; TBI is IT! / 5.0HO (306) SFI / 400cc air cooled twin
Transmission: 700-r4 / WCT5/ 6-speed close ratio
EDIT The picture has been swaped out with the actual correct numbers for easier use/verification. If some part of the thread doesn't make sense, now you know why
EDIT
The old setting is what the car had always been run at, ever since I bought it.
I bought a timing light and advanced the timing, to this setting. The pic explaines all. I tried 4* but when I gassed it and then let off (in first gear) I heard a quick noise from the exhaust. It sounded like a backfire? Not sure really. So I set it here, at ~2* and it feels great. From a roll of 5-10mph when I give it WOT it'll spin the tires, it never had that power before! I put in 91 octane gas....everything sound good? I was afraid of going with the 4* advanced because I did'nt want detonation. Maybe the car had been driven 150,000+ miles with 2* retarded timing and coulden't get used to a 6* change? Just wanted to be sure everything's ok here.....Thanks.
EDITThe old setting is what the car had always been run at, ever since I bought it.
Ah....so it was really retarded before then...no wonder it feels so much better...
The only thing is....I'm in park, idle is at 750rpm and i'll step on the gas a bit, real quick and bring the rpms up to ~3000 and let off....when it comes back down it'll stop at ~1500 for a second then slowly come back to idle...Is that normal?
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Great, thanks guys!
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
That picture is awesome! Seriously I'm adding this thread to one of the stickies at the top, that picture will help SO many people figure out where to set the timeing in their cars! As far as the thread itself, this does belong in the tech/general board, so off it goes... Thanks nidyanazo!
Bruce (90RS305)
Bruce (90RS305)
Glad I could help, but it was you guys that solved my question. So thank you guys.
Linson
Aug 21, 2015 02:12 PM
