Check Engine LIGHT!!!
Old May 9, 2005 | 02:40 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
After i put my open element on my car after i passed smog, I keep getting a check engine light at freeway speeds, why is this? The only thing i could think of is my IAT messing with me. The runs really good, no problem at all. The other thing too is that My EGR is brand spaken new got it from the Dealer and the EGR selinoid is brand new too. This happen after i put back on my open element....
Old May 9, 2005 | 02:54 PM
KintaroOe's Avatar
Car: '91 bird '87 Z28 '86 T/A
Engine: LO3 LG4(ls1 in works) 350
Transmission: 700R in all
Axle/Gears: wimpy 10 bolts
pull your codes, and see what is flagging. my car is bone stock except straight pipe off the manifolds, and it only pops up the SES during a 15min+ freeway cruise. it runs fine also. i couldn't really give you technical help.....except to use this as an excuse to swap a better engine in
Old May 9, 2005 | 03:09 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
Mine lights up on the freeway too. No problems here either. I checked the code and there was something wrong with an emissions sensor or something. The problem was, I removed it.
Old May 9, 2005 | 03:33 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
did you plug your iat back in?stupid question but i`d thought i`d ask anyways.
Old May 9, 2005 | 03:37 PM
84RIceEater's Avatar
Car: 84 Camaro. 90 integra
Engine: LG4, 1.6 (402hp)
Transmission: 700r4, JDM ITR w/ kaaz LSD
Just Pull the codes.
Old May 9, 2005 | 07:10 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
Yep, even though I'd bet it's an EGR code, pull the codes and let us know what it is.
Old May 9, 2005 | 09:20 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
well its not a hard code!!! its a soft code. How do i go about pulling that out? I dont have any reader except a paper clip!!
Old May 9, 2005 | 09:22 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
oh and the IAT is pluged in... But its not mounted anywere just out in the open and when i did cover it up it still turned the light on...
Old May 10, 2005 | 12:57 PM
little P's Avatar
Car: 89 Formula
Engine: 350ci, tbi
After i put on the open element , my check engine light came on too. Its the IAT . It would only come on after running about 5 minutes. Figured it was the heat. Mine is not mounted either, but i moved the Iat to a spot that is closer to the open element and the light hasnt come on yet.
Old May 10, 2005 | 01:58 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
thanks little p, Im going to try that today. YOU THE MAN!!!!
Old May 11, 2005 | 06:55 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
I put the IAT in the Open element and the light hasnt came on.. I think that fixed the problem. There should be a correction on the Instruction on how to put on an Open Element Thanks guys.
Old May 12, 2005 | 09:48 PM
90RS305's Avatar
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
It should be in there already, it states to mount it away from heat sources, or if your open element has the provisions for cut-outs (like my edelbrock one) then cut one out and stick it in there. I've had my open element for 2 years now and my car has never once turned a SES light...
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
