Chip or 1.6 RR
Old Dec 25, 2005 | 02:12 PM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
Chip or 1.6 RR
Well guys I do not have the money right now to get the car tuned in detail and I do not have that much money. So my question to you guys is if I should buy the TBI.com chip, or get a set off 1.6 RR. I wanna do the roller rockers cause they are cheaper and I need other things for the car, but will the car run ok on a stock chip and 1.6 roller rockers?
Old Dec 25, 2005 | 04:37 PM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
depends on how close to stock you are. If close to stock i'd buy the 1.6rr's.
Old Dec 25, 2005 | 04:52 PM
Engine: LB9, LB9
catback and open element.
Old Dec 25, 2005 | 05:01 PM
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
imo much better off going to a a 1.6rr but, don't get super cheapys! Cheap roller rockers usually don't last from what i've been told by people who know a lot more than me.
Old Dec 25, 2005 | 05:05 PM
Engine: LB9, LB9
I was looking at these http://www.sdpc2000.com/catalog/1956...Arms-87-UP.htm
Old Dec 25, 2005 | 05:48 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
The chip should help some, but unless you're there for a personal tune you won't be able to get the maximum benefit from it. 1.6RR's are a good mod, but like others have said, don't get anything cheap. The best mods for the money are either headers or gears/posi. If you can resist the money burning a hole in your pocket, I would try to save up for one of those instead. You should be half way there with what you have.
Old Dec 25, 2005 | 05:50 PM
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
that should work fine. As long as it's the narrow kind that's self aligning which it is you should be fine!
that's a stamped steel rocker arm not a roller rocker though so you know.
a full roller rocker has a roller fulcrum and roller truniun (think thats the right terminology)(2 bearings on it). Theres also roller tip rockers which are probably best for the money you spend on them that have 1 roller bearing on the tip of them(trunion lol dunno why i use big words).
The roller bearings cut down on valve train wear a decent bit and reduce a small ammount of friction therefore lowering oil temps and freeing up a very small ammount of power from parasitic loss.
Old Dec 25, 2005 | 06:19 PM
Engine: LB9, LB9
How about the semi-cheap STEEL ones.
Old Dec 26, 2005 | 10:34 AM
TierAngst's Avatar
Car: 78 Caprice Coupe
Engine: 355
Transmission: 4L60
The ones you linked will be fine, they aren't going to fall apart on you or cause any more wear on your engine than the stock rockers they're the same design just a bit less lift
Old Dec 26, 2005 | 11:24 AM
jimp2001's Avatar
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
1.6 RR are good on my car, I haven't installed any other mods yet.
Old Dec 26, 2005 | 12:00 PM
Car: 91 RS
Engine: 350 TBI
I still say save your money for some headers or posi/gears. You'll get much more of it.
Old Dec 29, 2005 | 12:41 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
My advice, which I was going to do before wife wasted all ***** money get chip burning equipment. Total cost would be 180 dollars or so.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Gunner242
Dec 25, 2015 04:49 PM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
