Throttle Sticking - Not As Easy As It Sounds!
Old Jan 16, 2006 | 06:19 PM
Maverick_IX's Avatar
Car: 1991 Chevrolet Camaro
Engine: GM 5.7L H.O. 350HP
Transmission: Rebuilt 700r4/Shift Kit/Servo
Recently, I installed a larger bore (46mm) TB unit on my camaro.
The unit has a rebuilt throttle shaft with new bearings and no play in the shaft whatsoever.
After first installing the acclerator was hard to depress, and I came to the conclusion that the throttle blades were sticking at idle (a fairly common problem), I adjusted the IAC to prevent the blades from closing completely and the throttle can easily overcome the vaccum and the accelerator easily depresses and take off is smooth.
Now, the odd problem I am having is that the throttle sticks after speeding up to any regular speed and letting off the pedal. The car will hold the rpms steady or slightly decline, almost like the cruise control is on. If you quickly romp the throttle it breaks the sticking free and the rpms drop like they should, but not if you just let off the throttle.
Is this a matter of the blades getting physically stuck at higher rpms or that there is not enough vacuum to pull the blades back closed or is it just a faulty throttle shaft?
ANY SUGGESTIONS, OR ANYONE HAVE THIS PROBELM BEFORE?
Old Jan 16, 2006 | 08:08 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
I have it all the time.
The vacuum actually makes in harder for the throttle blades to close as there is alot of force on the blades when vac is present. Combine this with the TV cable and throttle cables pulling on it, and the throttle may not close on its own.
Check to make sure that the throttle cable isnt under tension when the throttle is closed. If it is, then slightly elongating the eye in the throttle cable end might help.
Old Jan 16, 2006 | 08:14 PM
Throttle cable isn't tight in tension when they throttle is closed. I have heard that there is a spring that can be swapped to allow the blades to close quicker, but this was for a carb? You think that could that be the problem on a TBI?
Old Jan 16, 2006 | 08:23 PM
Old Jan 16, 2006 | 08:48 PM
Car: 88 Camaro SC
Engine: SFI'd 350
A carb return spring is what was likely used. Itll work and help the throttle close, but may also increase pedal effort
Old Jan 16, 2006 | 09:05 PM
Few questions:
Are carb return springs difficult to install?
When you check the throttle cable for tension, is the car supposed to be idled or shut off?(it's been a while)
Is there anything else you can do or is this something you have to live with?
Old Jan 17, 2006 | 07:31 AM
Car: 88 Camaro SC
Engine: SFI'd 350
With the car shut off, close the throttle all the way by hand and make sure there is still a very small ammount of slack in the cable. Its likely to be fine but with the manufacturing tolerances of some of these parts things can be a little off sometimes.
The spring is easy to install. Clip it to the throttle shaft and to something else nearby thats stationary and thats it.
Old Jan 17, 2006 | 08:16 AM
kevm14's Avatar
Car: 93 Caprice 9C1
Engine: L05
Transmission: 4L60
Sounds to me like the 46mm TBI has some machining faults. Maybe the bores aren't perfectly round or the right diameter. Maybe the new bushings are too tight. Maybe the line boring slightly shifted the shaft out of center...
Old Jan 17, 2006 | 11:17 AM
From all I can tell the bores are very precise (no rubbing but no excess space between the blades and the bore). The throttle shaft is brand new and also doesn't seem to have any play in it. As far as the bushings being to tight, I'll have to tear the air breather off and check again.
I've only heard good things about this guys TB's unless this one just has an error. It's a kit form Xtreme-FI.
Old Jan 17, 2006 | 01:09 PM
Okay so if the the throttle cable is tight how can you adjust that, or elongate the eye?
Old Jan 17, 2006 | 01:35 PM
kevm14's Avatar
Car: 93 Caprice 9C1
Engine: L05
Transmission: 4L60
Just pull the throttle cable off the linkage and see if you can pull it further. The gas pedal will move up as you pull past the closed throttle point on the cable. I highly doubt that's the issue, considering this TBI is based upon and still highly resembles a stock TBI.
Old Jan 17, 2006 | 02:21 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Double check that the return spring on the TBI unit is clean and free of funk. That spring will corrode a bit and create all kinds of funk in there that impedes the movement of the spring. A few hits with carb cleaner and a toothbrush can make the TBI operate much smoother. I would add a small drop or two of clean oil to it as well to ensure that is stays lubed.
Old Jan 18, 2006 | 03:02 PM
It's a new spring, but doesn't matter.
While I was checking everything out I decided to adjust the TV cable properly because I was getting extremely late shifts.
The good news is that the throttle no longer sticks (maybe TV cable was in too much tension), and shifts are where they should be.
The bad news is that I have no 4-3 3-2 4-2 downshifts whatsoever, even at WOT. (The reason I used a rebuilt stock TB was so that all the linkage would be correct so it is my understanding that the TV cable is set correctly)
The no downshift must be due to another reason.
Old Jan 21, 2006 | 10:39 PM
ratrodjon's Avatar
Car: 89 CAMARO, GUTLESS WONDER
Engine: 305 TBI
If you were getting late shifts before and no kick down now i would guess cable is not adjusted properly. btw if any one starts building big power and has the throttle stick, have your hand on the ignition key ready to shut it off before you go blip the throttle. I know a guy that was in a full body cast and laid up for months because he did this and the throttle decided to stick wot.
Old Feb 7, 2006 | 06:51 PM
Throttle just starting sticking again, I am still battling the transmission/tv cable issue but it seems to have noe bearing on the throttle sticking/hanging rpms.
I don't see how the uneven wearing can still be a factor is the shaft and bushings are new.
I considered using a light carb return spring(but I needed some pics of how this is set up first)
Old Oct 22, 2009 | 04:14 AM
92Vortec's Avatar
Car: 1992 Camaro RS
Engine: 350, Vortec Heads, LT4 Hot Cam
Transmission: 4L60
Re: Throttle Sticking - Not As Easy As It Sounds!
I know this thread is old, but I was searching for a cure for my problem which seems to be exactly what yours was! I just put a built 350 in my 92 RS and have the same problems you described as "throttle sticking after speeding up to any regular speed and letting off the pedal. The car will hold the rpms steady or slightly decline, almost like the cruise control is on. And if I "quickly romp the throttle" it breaks the sticking free and the rpms drop like they should, but not if you just let off the throttle. Further more, it actually speeds up more! WHAT WAS YOUR CURE!!!
Old Oct 22, 2009 | 05:24 AM
berlin305's Avatar
Car: 1987 Iroc Z 1990 RS 1991 RS
Engine: 454 soon 496
Transmission: Soon T56
Axle/Gears: 308 Posi
I am just reading it now. Well mine did the same thing you need a new spring on the throttle or heavier spring. Because its not springing back closed fast enough. It might be b/c the spring is also stretched. I would say go get a new one don't bother messing with the old one. You will see a difference.
Old Oct 22, 2009 | 05:34 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Then why at the same time, are you posting statements like this in the other tread?
I`ve been happy with mine so far. It has only been in for 1 month, but so far so good. It is a ported (50mm) Rochester TBI 220 stock unit. Flows 700 cfm. Great unit! they also have a really nice pressure regulator for only $40. I got 9C1 injectors from them, too. I`m running imine with a Vortec headed 355 with LT4 Hot Cam & 3.23`s. I used to be an L03 car. I don`t even have 500 miles on the motor yet!
http://www.xtremefi.com/QA.htm
In this tread here.
https://www.thirdgen.org/forums/tbi/...arket-tbi.html
Old Oct 22, 2009 | 05:38 AM
berlin305's Avatar
good question?
Old Oct 23, 2009 | 12:15 AM
92Vortec's Avatar
Car: 1992 Camaro RS
Transmission: 4L60
It ACTED same way as this guy's car. Found out it was my TPS going bad.. replaced it...good to go.
Old Oct 23, 2009 | 04:57 AM
thomas1976's Avatar
Car: 91 Trans am
What did the TPS do?
Old Oct 23, 2009 | 10:24 PM
Car: 88 Camaro SC
Engine: SFI'd 350
The TPS effects the throttle follower. If the ECM thinks the throttle is open, it will retract the IAC to provide additional airflow when its not needed.
Old Oct 24, 2009 | 05:08 AM
thomas1976's Avatar
Car: 91 Trans am
Was wondering how the tps would cause the trottle blades to stick.
Old Oct 25, 2009 | 07:37 AM
yupitsdadsbird's Avatar
Car: 91 RS
Engine: 5.0 tbi
cause it's not actually the throttle sticking but the tps makeing the ecm think the throttle is open and turning the whole system stupid and keeping the engine at a higher rpm.....fix: new tps or BFH and wish it the best a luck lol
Old Oct 30, 2009 | 07:07 PM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
any upates?
Old Nov 18, 2009 | 12:20 AM
89Camaro89MI's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Yeah, I've got a similar problem. Car speeds up after I let off the gas. I can slide my foot under the pedal to bring the RPM's down.
I thought it was the spring for a while, but it sounds like the TPS.
92camaroJoe
Jul 29, 2023 07:57 PM
db057
Sep 4, 2015 07:57 AM
BurlyChev
Aug 16, 2015 09:08 PM
92camaroJoe
Aug 13, 2015 06:07 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
