our plugs
Old Jul 8, 2006 | 12:24 AM
invaderzim1915's Avatar
Car: 1989 rs camaro
Engine: 305 TBI
Transmission: auto
our plugs
I hate our pluges at lest the 89 rs 305 TBI it took 4 hours to chang them and you have to be under the car for one the on top the all overe the place that was the hardest plugs and wires i have ever done
Old Jul 8, 2006 | 08:20 AM
Rockyd's Avatar
Car: 89Z28 Vert
Engine: 350/tbi
Axle/Gears: 3.27 Posi
sorry to hear that i have a 91 took about 30 min all from underneath on a lift made it easy
Old Jul 8, 2006 | 01:20 PM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
I feel your pain, when i did mine before removing all the smog **** and lotsa of pesky in the way stuff it took me 3 hours on a lift to do them too (i'm definetly not proud of this) and most of done it much faster. Now that the air pump lines are outa the way and some junk is relocated it takes about 20-50 mins to do plugs and wires correctly (antiseize on wires and plug thread and checking all the gaps).
Old Jul 8, 2006 | 03:35 PM
thepoz89's Avatar
Car: 89 Firebird 89 Formula one red one black
Engine: 350, 355
Too easy. Try LT1.
The best way to do the plugs are jacking the car up so you can lean against the car as you pull plugs 1,2,3,4,5 from the top and then dive underneath to get the rest. Buy a spark plug socket and use a bench grinder to "shorten" the socket. Use a spark plug for reference so you dont grind too much off. Use a 5/8 wrench on the socket you made for the tight spaces.
Tip: Grind from both ends of the socket. Slp makes one for 30 bucks. You can make your own for 5.00.
POZ
Old Jul 10, 2006 | 12:39 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Originally Posted by thepoz89
Too easy. Try LT1. POZ
Too easy. Try VAN with headers or 454 in Van
LS1s are a PITA as well.
Old Jul 10, 2006 | 11:46 AM
thepoz89's Avatar
Engine: 350, 355
ouch, that looks like a pain in the.... Why bother with chrome valve covers? You cant see em!
Old Jul 10, 2006 | 12:24 PM
Green89IROC305's Avatar
Car: 91 Z28 - using 87 electricals
Engine: 383 HSR EBL
Transmission: 700R4 - Stage 3 Fixed Pressure
Axle/Gears: GM 3.08 POSI
its not to bad to get them all from the top ive done it a couple of times. takes me aabout an hour or so.
Old Jul 10, 2006 | 08:05 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Becuase I got them for free (worked for Autozone at the time) and the other set was a dirty, crappy set from a 200,000 mile 350 TBI.
Old Jul 10, 2006 | 08:12 PM
seanof30306's Avatar
Car: 1989 Formula WS6
Engine: L03 305 TBI
Axle/Gears: 10 Bolt; 3.42 Posi
Because HE knows they're there. Half the stuff we do to our cars are for the same reason.
Old Jul 10, 2006 | 08:15 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
LOL
Old Jul 10, 2006 | 08:56 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
POZ
Agreed. You can also get one off of ebay for $9. Try a search or two using key words like "spark plug socket" and you will get all kinds of info and pictures. They make plug swaps very easy.
The hardest car that I have changed plugs on to date is a V6 4th gen.
wigmobile
Feb 26, 2025 02:56 PM
gta892000
Aug 11, 2019 11:16 AM
92rsvortec350
Sep 10, 2015 10:54 AM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
