TBI engine swap?????
Old Oct 15, 2000 | 11:39 PM
robleegordon's Avatar
I now have a LO3 92 RS!!!!
I read in the tech. section that you can put a carb onto you TBI engine. I also read that after you do this, you can get rid of the ECM??? Is this true??? I want to put my freshly built 327 SBC into my car, but wasn't too sure of the wiring problems I might encounter??? Can this be done easily??? Is my trans. computer controlled??? (i have auto) If I swapped engines and followed the steps in the tech. article, will the ECM become useless??? Please let me know!!!
Old Oct 16, 2000 | 01:32 AM
Tas's Avatar
Tas
congrats. how many miles it have? the 305 can go a lot of miles. if you have alot maybe you can try doing heads cam and intake. how strict are the emissions there? 327s make power from having big cams and reving high which makes for bad emissions.
-Tas
'89 Formula WS6
305, TBI, auto, 14x3 chrome flat based open element with K&N, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Super GRK_Taz World
EFI & Intake Options
AOL IM: superGRtaz
ICQ 82881207
Old Oct 16, 2000 | 07:38 AM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
robleegordon, I haven't swapped anything over to carb yet but I am going to when I swap my engine. Yeah the ECM becomes usless and u don't even need it anymore. As for the wiring and such, I am not sure. You would have to ask someone that has already done it. I would go over to the carb section and ask or go to this thread
http://www.3rdgen.org/ubb/Forum17/HTML/000040.html
I asked pretty much the same question and a lot of people posted about what I would need, what I might loose. stuff like that. Check it out.
Hope this helps.
Eric Natzke
91 Firebird 305 TBI (ZZ4 summer of "01")
ASCD Ram Air Hood-3" custom exaust-Flowmaster 80 Series-No Cat-Edelbrock TES Headers (coated)-March Pulleys-TBI Spacer-K&N Open ELement-TransGo Shift Kit-B&M Supercooler 28,000 GVW-Hypertech Thermomaster-160 Stat-3:42 GM Gears-Auburn Posi Unit-Edlebrock Strut Tower Brace-MSD Superconducters-Accel Cap & Rotor
-Rapidfire Plugs
265/50/R15 Tires-Emmison's all Gone
http://hometown.aol.com/J007Golden/index2.html
[This message has been edited by 91Bird305 (edited October 16, 2000).]
Old Oct 16, 2000 | 10:27 AM
As for emissions, there are none where I live(lucky me) so I don't need a cat of muffler. The car has 57,158 miles on it, but it's a dog and I want a little more power. I've built street rods before (74 Camaro,41 ******
and a 63 Nova, but I didn't have any fuel injection or computers to screw with. I'm new at this part.
Old Oct 17, 2000 | 12:22 PM
burntblues's Avatar
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
I haven't yet switched over to carb on the 350, but when the computer becomes useless, so does the stock distributor. Also, you'll have to change out fuel pumps, or get and adjustable fuel pump, because a carb can't accept the amount of pressure that the fuel pump blows. You'll blow the needles out of the carb. There are a few other things, that I'm not really sure about, if you have an auxilary fan, one of them will be controlled by the ecm so you'll probably have to add a switch into the block and splice it into your fan. But when you do carb out the car, it'll probably be like a diet, since you can ditch all of the electrical junk, and besides, who doesn't like working on a carbed out car better? I think that in 92 they switched over to a PCM (powertrain control module) instead of the ECM which manages only the engine. But with all of the people that do these engine changes, I don't think that it would be a big deal, at the most you'll probably loose your overdrive.
Good luck,
-=-Mike
1989 RS.. Newly installed 350,bored out 30 over, Hypereutectic pistons, double roller cam, double roller timing chain, accel wires, blue streak cap and rotor, platinum plugs, chevy caprice 350 chip.
Old Oct 17, 2000 | 03:58 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
you wont lose overdrive, but you will lose your torque converter lock up unless you get a "torque converetr lock-up kit". i know that TCI has one available through jegs,the part nymber is 890-376600. B&M also has ne through jegs. the part number is 130-70244 withmech. speedo, and 130-70248 with electric speedo.
the TCI one is like 70 bucks and the B&M one is like 170.
hope this helps.
-brian
1991 Camaro RS
Ultra Blue Metallic, T-Tops
GM 350 HO Crate Engine - Vortec Heads, Edelbrock Performer Vortec Intake, Holley 670 CFM Throttle Body, Open Air Cleaner w/14"x3" K&N, Edelbrock TES Headers, Edelbrock Victor Series Water Pump, Accell Superstock Wires, Cap, and Rotor, MSD Blaster Coil, Hypertech Fan Switch & Thermomaster Chip, AC Delco Rapidfires, 3" Cat Back, Flowmaster 40 Series Muffler
700R4 - 2,400 Stall Converter, Vette Servo, Shift Kit, B&M Super Cooler
Brian's 1991 RS
Central NY F-Body Association
z28boy@twcny.rr.com IM name: Z28 Boy
Old Oct 17, 2000 | 10:45 PM
Awesome, also, what type of trans. Does my car really have, I'ts the stock Hydramatic 4L60, is this a 700R4???? Just wondering.
Old Oct 18, 2000 | 06:35 PM
DM91RS's Avatar
Car: 91 RS
I rewired my last RS with a 700R4 with a $10 switch, inline fuse and a wiring diagram from a Chey Hi Performance and never had a bit of trouble from it. What this does is leave 1st through 3rd on the converter and locks up 4th only. Need any more info I can look into my archives and find the part number of the switch and wiring diagram which might be something others might find useful. By the way the 3 years spent with an automatic trans were the pits! Driving since 1970, all manual except for this unwanted venture into no clutch downshifting. Good luck!
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
InfinityShade
Aug 22, 2015 08:00 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
