AFPR mod...results
Old Nov 7, 2000 | 01:28 PM
mike ghoul's Avatar
AFPR mod...results
Just got my AFPR in, set at 15 PSI. Very good mod, I can definetly feel the difference with it in.
As far as I know these LO3's are almost lean from the factory, so adding headers exhaust and an open air filter only makes this worse.
I am going to the track this weekend, and hopefully with the lower temps, I'll get a nice new(lower) e.t. to report to you.
Old Nov 8, 2000 | 11:59 AM
Godti's Avatar
Car: Trans AM
Engine: 305 TBI
Transmission: 5spd
Can you install a fuel pressure guage with the AFPR?? And can you install that inside the ****pit??
Old Nov 9, 2000 | 02:20 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Hey Mike, what AFPR did u order? Or did u make your own out of the exsisting one? Thanks
Eric Natzke
91 Firebird 305 TBI (ZZ4 summer of "01")
ASCD Ram Air Hood-3" custom exaust-Flowmaster 80 Series-No Cat-Edelbrock TES Headers (coated)-March Pulleys-TBI Spacer-K&N Open ELement-TransGo Shift Kit-B&M Supercooler 28,000 GVW-Hypertech Thermomaster-160 Stat-3:42 GM Gears-Auburn Posi Unit-Edlebrock Strut Tower Brace-MSD Superconducters-Accel Cap & Rotor-Rapidfire Plugs-265/50/R15 Tires-Emmison's all Gone
http://members.aol.com/j007golden/91firebird.html
Old Nov 9, 2000 | 03:43 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
15 psi!? that sounds like alot dude, if your car doesnt get substantially slower I would be surprised
Old Nov 9, 2000 | 03:45 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
What would be a good? Like 12-13? For something like my car and its mods.
Eric Natzke
Old Nov 10, 2000 | 02:01 AM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
whatever makes it run fastest, every car is different
Old Nov 10, 2000 | 03:13 AM
mike ghoul's Avatar
I am using a turbo city AFPR, it's the exact same as if I adjusted the stock one, I'm just lazy.
You can put in a gauge in to monitor the pressure, but you would most certaintly keep that under the hood, as it requires being hooked up to the fuel lines, not a good thing to have in the car.
I thought 15 psi was a little high myself, but it is running real good right now, in the past I had gotten lean exhaust engine codes, so i think this has helped correct the problem. Plus the spark/intake/exhaust mods done to the car make this a pretty good setup. It feels faster, but I'm going to the track this weekend to be sure.
1990 Camaro RS
305 TBI Auto
K&N Open Air Element, Edelbrock Performer Intake, Edelbrock Headers,Catco Hi Flow Cat, Edelbrock Exhaust, Hypertech Underdrive Pulley's, Jacobs Ignition, Fast Chip PROM, B&M Shift Kit, B&M Mega Shifter, 3.73 Rear with Auburn Limited Slip, KYB GR2 Gas Shocks and Struts, Eibach Pro Kit Lowering Springs, Edelbrock 3 Point Strut Tower Brace, Baer 13 in. Slotted Rotors with Metallic Pads, American Racing Torq Thrust II 16x8 Wheels with Toyo 245 50 VR 16 Tires, 3 in. Cowl Hood, A little weight here and a little weight there.
Old Nov 10, 2000 | 08:16 AM
scauffiel's Avatar
You can also buy electrical pressure gauges that send the pressure to the gauge via wire so that you don't have fuel in your interior. As usual they cost a lot more than the regular gauge.
Steve
Old Nov 10, 2000 | 08:47 AM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
Hey Mike, where did u get your Jacobs coil?
Eric Natzke
Old Nov 12, 2000 | 04:18 PM
Paul Holmes's Avatar
How do you guys figure out your fuel pressure, I have a JET AFPR on my tbi and a Autometer fuel pressure gauge which reads 15 to 18 all the time. I'm basically reading the pressure from the pump.
91RS-STROKER
Old Nov 12, 2000 | 07:15 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
a gauge inline does the trick, i have one mounted on one of the ports of my external regulator
I run about 19 psi with custom programming, motor isnt stock
[This message has been edited by Pablo (edited November 12, 2000).]
Old Nov 13, 2000 | 02:16 AM
mike ghoul's Avatar
I got my jacobs ignition directly from jacobs(that was a mistake!) but summit sells them for about $50 cheaper, so I would get it from there. It's really easy to install(the plugs on these cars are annoying) and you do get the bonus anti theft switch for free. I wired mine under the hood and don't really use it, but it is there.
Old Nov 13, 2000 | 04:03 PM
88'camaro305TBI's Avatar
Car: 88 IROC
Transmission: auto
Hey Mike, so did you go to the track this weekend? I'm just really curious on how you did with your AFPR mod, thanks, Pat
Mods:Hooker Aerochamber 3" exhaust, gutted kitty,
March 2 piece underdrive pullies, smog pump gone,;these two made a very noticable difference.
14x4 K&N open air element filter-the best mod so far
Eibach springs with KYB's all around.
Appearance: Harwood cowl hood, Z-28 wing, painted black(7/20/00)-original color was light blue
*All these mods were made this year
Stock Options:117,000 miles on motor, 5spd, TBI, 305, T-tops
Run a best of 16.7 @85mph with traction problem. Have to try again sometime.
Old Nov 14, 2000 | 01:06 AM
mike ghoul's Avatar
I missed the last test and tune of the season at MIR, so I don't have any new numbers. But i do plan on going for some g tech runs this weekend, and I have about 20 runs on this for a baseline, so I will be able to give you something in about a week.
Best g tech run in the past was a 14.7 at 99mph.
1990 Camaro RS
305 TBI Auto
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
2012sergen11
Oct 13, 2015 07:38 PM
Reid Fleming
Oct 10, 2015 09:56 PM
alpine247
Sep 16, 2015 05:25 PM
355tpipickup
Sep 4, 2015 05:32 PM
