TBI computer Gurus please help
Old May 24, 2001 | 10:00 AM
Kyle F's Avatar
My brother has just got done building a kick *** 305 that should have enough goodies to make around 300hp (we hope) I think it will be more like 275, but any who. I have a TTA and just got the Turbo link scanning software for it. IT sayes that it will work with soime TBI cars and trucks with the K engine code. NOw from what I know about other GM products I am assuming this is found in the older Caprices and trucks, say early 90's. We want to use the scannin software in my Brothers TBI to tune everything up properly and make sure everything is running correctly so do we need to change computers? This software reads throught the AlDl port and is a real time analizer.
If we need to switch computers is it worth it? Which computer do we find, a 350 trucks and put a custom fast chip in or what.
Le ma know what you think is best because we are unsure about what all good or bad can happen.
89 Trans Am Turbo 3.8L All stock 43,000 miles #1053 of 1555
Past Thirdgen:
86 Trans Am w/ built 355TPI with SLP goodies and too much other stuff to List. One sweet *** car, wish I would have had a good enough Job to pay insurance on three cars so I could keep it, but for a 89 Turbo Trans Am w/ Low miles, I think I made the right choice!
Old May 24, 2001 | 10:08 AM
JPrevost's Avatar
Car: 91 Red Sled
Yo, Kyle e-mail me, we gotta get together some time for lunch or the weekend, maybe go to the track.
About your brothers maro, you will need a 7747 ecm. It's the same as the 8746 but it doesn't have an IAT (intake air temp) sensor. I think there are a few wires that need to be switched, but I've also been told that you don't need to bother and that it's a direct plug in. I'm doing my own chip programming and I could help your brother out if you need a custom chip burned. You just gotta cart my a$$ around while my car is acting up.
The 7747 ecm is really popular and that is the only way for that software to work. Our ALDL (8746 ecm) has a funky code and nobody has bothered to impliment it into their scanning software because it wasn't very popular. Now that the "hack" for the 8746 came out I've been working with it and getting a good handle. Hopefully Craig over on the eprom board will include the 8746 with his next software release.
, Jon (350 TBI!)
91 Red My website
Old May 24, 2001 | 11:18 AM
Brent's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Kyle F:
I have a TTA and just got the Turbo link scanning software for it. IT sayes that it will work with soime TBI cars and trucks with the K engine code. NOw from what I know about other GM products I am assuming this is found in the older Caprices and trucks, say early 90's. We want to use the scannin software in my Brothers TBI to tune everything up properly and make sure everything is running correctly so do we need to change computers? </font>
If the car is a 89-92 you can probably use the Turbo Link on it. I would try setting Turbo Link to an 89-90 Caprice and see what happens.
Since you changed the engine radically from stock you will need custom chip work.
The 7747 *does* plug right in. I did one last weekend.
Old May 24, 2001 | 11:31 AM
JPrevost's Avatar
Car: 91 Red Sled
Brent, thanks for joggin my memory, I almost forgot about the caprice. The Turbo Link website says it works with the caprice, if that's true, then it has to work with the 8746. It it does, Kyle, we definatly need to get together sometime.
, Jon (350 TBI!)
91 Red My website
Old May 24, 2001 | 12:36 PM
NotDadsW41's Avatar
It works with the Caprice. I use it on my 89. I think TL just specifies 5.7L TBI though. I don't think it make any difference what vehicle it's in. I used it on my 91 p/u. And I use it on my 92 Astro van, on the 4.3L TBI setting of course.
Old May 24, 2001 | 12:41 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
275 my A&& if car craft got 325 with their combo......... I have added more lift, Full roller valvetrain, cleaned up the heads. Now tell me how I can come up with less horse power....
Brian
1989 Camaro RS
305 TBI in process of Rebuild
Old May 25, 2001 | 08:42 AM
Kyle F's Avatar
Because, your in the real world breating under the hood and not on a dyno stand!!!! We will see, besides its only what makes it to the pavement that counts.
Whats that, you got beat by a V6? How did that happen?
Old May 26, 2001 | 05:13 PM
Well beat by a v-6 hummmmmm as I recall it didn't happen and for that I will put your turbo on backwards so you can boost your hair dryer )))) Yes he does have a KILLER TTA #1053
Brian
92firebirdguy
Sep 1, 2016 07:53 AM
BLK87Z
Sep 18, 2015 11:29 PM
89bird2.8
Sep 18, 2015 07:46 PM
Glowsock
Sep 11, 2015 11:09 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
