whats wrong is it tbi
Old Jul 29, 2001 | 01:56 AM
firbird's Avatar
I donot know what is wrong my idle is going up and down, i would say between 1000 to 700 when it idles. Is it because the computer can’t handle my new 350 with a Holley tbi unit or is something else wrong? Did you have this problem? and i have pluged all my hoses for my heater core and it is leaking when i run it it has a clamp on it but i did not know it would be under pressure still with out it hooked up to the radiator, does it have a pump in it because it still seems under pressure and i dont really know about that stuff yet.
Oh yea have you herd about the west Nile virus carried my mosquitoes, it think that they were up in new York and jersey well any ways it just happened to show up in my little town in Niceville in Florida. Many birds a cow and a boy in my town has died so far and they have a warning not to go out side during dark. Well i have to work on my car somehow and i got bitten my lots and lots of mosquitoes soo.. i have woke up at 11:30 and feel like my head i about to explode #1 symptom of it and my back hurts #2 symptom 3 fever not yet! oh well its 2 my time and still feel bad and if you don’t see me any more well..
Old Jul 29, 2001 | 02:24 AM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
Are you running a 350 chip? Wouldnt that have something to do with the injectors feeding enough gas into the car since it still thinks its a 305? Dunno, but I kind wished i had your problem instead of my problem of being slow (minus the west nile virus and all)
Chuck Kulchar
1991 RS
Open Element w/K&N
3.42 - posi - disc
3" cat and Force II cat-back
Old Jul 29, 2001 | 02:50 AM
firbird's Avatar
well i have the stock chip and i really think it is running rich and i will have to do that thing with the oxygen senor to get to have the right amout of gas. look like another sleepless night for me!
Old Jul 30, 2001 | 10:14 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
Your not suppose to plug the heater core lines but put a piece of pipe to run the one hose to the other so that pressure doesn't build up there.
91 Camaro RS 5.0L Black Convertible 700R4
** Added so far **
*GM Wonderbar,Alston SFC's,spohn LCA's and Panhard rod
*Turbo City Inj Spacer
*Dual Snorkel Air Filter
*March Performance Pulleys
*GM 3.42 Gears with OEM Zexel POSI
*Edelbrock headers
*3" High Flow Cat
*3" Dynomax Exhaust
*Walbro 255 lph Fuel Pump
***Future 330hp Vortec Crate with LT4 hotcam and 454 TBI
Old Jul 30, 2001 | 12:13 PM
NotDadsW41's Avatar
I'll bet you aren't running rich but rather lean. I just recently went thru this on my 89 9c1 and it turned out to be a weak fuel pump was the cause of my troubles. It would hunt for the idle between 600-1000. Nearly stall at 600 then jump back up to 1000.
Old Jul 30, 2001 | 12:23 PM
Azarel's Avatar
If the hunting idle is due to a weak fuel pump, would that explain why in the morning my car wants to idle like that? my Rpm will climb to about 1000 then fall down to around 400 or so, it acts like it wants to cut off then it raises the idle again. I replaced the IAC on it and still no avail.
1992 25th Anniversary Ed. Camaro RS
Old Jul 30, 2001 | 03:10 PM
firbird's Avatar
my engine can idle 400 just fine. when you just swap a engine in and put a 350 in a put holleys tbi on doesnt run rich at first not lean
Old Jul 30, 2001 | 08:14 PM
Jza's Avatar
Jza
sucks, huh? work in the day and roast and bake, work in the evening and feed the local mosquitos, or work at night and get frustrated because you have to balance a light along with your tools or cant find a socket when it rolls under the car.
ah i love cars.
Old Jul 31, 2001 | 04:39 PM
firbird's Avatar
i need a garage
Old Jul 31, 2001 | 05:11 PM
HrdRockA4305's Avatar
Well, since it applies to the topic, do you think a just-starting-to-die fuel pump could cause this? Mine likes to start, run about 2 seconds, then die unless you mash the gas in time. Start it again and its just fine. It does this about 1 in 3 times you try and start it. No biggie, just makes me wonder a bit.
88 Camaro (not an RS, or an IROC, justa camaro.)
305TBI/700R4/2.73
14" Open Element and Flowmaster 80 seires
Next up: headers and gears
92firebirdguy
Sep 1, 2016 07:53 AM
Dyno Don
Jan 24, 2016 08:24 AM
89bird2.8
Sep 18, 2015 07:46 PM
Glowsock
Sep 11, 2015 11:09 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
