Stock Timing
Old Oct 16, 2001 | 06:26 PM
cobrakiller1989's Avatar
6*
*1989 RS
*Red, Daytona Turbo fiberglass hood, chrome 16x8 IROC wheels
*355 CID
*TPI ported plenum, SLP siamesed runners, Edelbrock high flow intake
*Edelbrock TES Headers (getting SLP 1 3/4)
*Richmond 3.73, Auburn Posi
*Modded 700-R4, 2800 stall converter
[This message has been edited by cobrakiller1989 (edited October 16, 2001).]
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Stock Timing
For the LO3 is 0* correct?
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
http://members.aol.com/j007golden/91firebird.html
For info on certain parts or mods go to the site below
http://members.aol.com/j007golden/modeval.html
Old Oct 16, 2001 | 06:28 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
ITS 0 B*TCH AND U WILL SEE!
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
Old Oct 16, 2001 | 06:31 PM
YOUR WRONG
Old Oct 16, 2001 | 06:38 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
I AM RIGHT!
Old Oct 16, 2001 | 07:36 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
He's right.
Old Oct 16, 2001 | 07:41 PM
uhhh...who is right? i am starting to have doubts about my original assuption is why i asked
*1989 RS
*355 CID
Old Oct 16, 2001 | 10:05 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
I'm right b*tch now get off my thread.
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
Old Oct 16, 2001 | 11:11 PM
oh d*mn...i think that homo is right...oh well statistics say that he would have had to atleast guessed one right answer by now.
*1989 RS
*355 CID
Old Oct 17, 2001 | 12:08 AM
JPrevost's Avatar
Car: 91 Red Sled
0 base sucks, bump it to 6 and watch for spark counts (knock) with a scanner. If you have some knock either run higher octane or retard timing to 4 and try again.
, Jon (350 TBI!)
91 Red My website
Old Oct 17, 2001 | 12:27 AM
Tas's Avatar
Tas
how much do scanners go for?
Old Oct 17, 2001 | 01:26 AM
BahamutRS's Avatar
Ten easy payments of $99?
Old Oct 17, 2001 | 01:14 PM
JPrevost's Avatar
Car: 91 Red Sled
<font face="Verdana, Arial" size="2">Originally posted by BahamutRS:
Ten easy payments of $99? </font>
WRONG!!! Try less than $10 in parts and gas if you make the cable and use the free scanning software, borrow a laptop.
https://www.thirdgen.org/messgboard/...ML/002597.html
, Jon (350 TBI!)
91 Red My website
Old Oct 17, 2001 | 01:46 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
i assume you guys are takling about base timing...if that isthe case, you might think i am crazy..or my car is.
mine is set at about 12 degrees. is this like nuts or what? that is the only way that i can get the car to run right, without backfiring and spitting ansd sputtering and poping and all that other good stuff.
what could be the problem here? distributor in wrong?
-Brian
1991 Camaro RS
GMPP 350 HO crate engine - 454 TBI, MSD ignition, SLP exhaust, everything is new
700R4 - 2,400 stall converter, vette servo, shift kit
My car's webpage - z28boy.cz28.com
President - Central New York F-Body Association
Email - z28boy@twcny.rr.com
AIM - "Z28 Boy"
Old Oct 18, 2001 | 10:43 AM
Kyle F's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Z28 Boy:
-Brian
</font>
Did you remember to disconnect the little brown wire before setting your timing?
If not maybe you timing chain has walked on you.
89 Trans Am Turbo 3.8L All stock 43,000 miles #1053 of 1555
Past Thirdgen:
86 Trans Am w/ built 355TPI with SLP goodies and too much other stuff to List. One sweet *** car, wish I would have had a good enough Job to pay insurance on three cars so I could keep it, but for a 89 Turbo Trans Am w/ Low miles, I think I made the right choice!
Old Oct 18, 2001 | 10:44 PM
JPrevost's Avatar
Car: 91 Red Sled
Brian, the 330hp requires 10 degrees base timing. I just noticed this after scanning through the install instructions. They even sugest the exact timing advance at certain rpms, this is GREAT because now I know how the timing should look .
, Jon (350 TBI!)
91 Red My website
Old Oct 19, 2001 | 02:03 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
[This message has been edited by brodyscamaro (edited October 19, 2001).]
Azrael91966669
25
Jun 20, 2017 04:04 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
camaro71633
Sep 1, 2015 10:24 AM
Exxon Limited
Aug 9, 2015 08:13 PM
Thirim
Aug 9, 2015 06:19 PM
