Mid range horsepower boost for cheap
Car: 92 RS AKA the Aluminum Falcon
Engine: 5.0L TBI
Axle/Gears: 4.10
Hey guys, I'm pretty new to the site and camaros as well. I know a decent amount, but hteres a lot i dont know at the same time. Basically i've been looking at foils, spacers, and feeders for my 92 rs TBI. They seem cheap and most of them promise to free up some horsepower in the mid range, which is what i need. My car launches hard, but it loses power too fast in the higher ups.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Mid range horsepower boost for cheap
Have you read the two "Ultimate TBI" tech articles? They list everything you need to get more power out of a TBI engine.
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
Transmission: 700r4x2
Axle/Gears: 3.23 bw, 2.73 10 bolt.
then you get to go through your initiation into the fraternal order of bloody knuckled thirdgen owners when you replace the factory fuel pump to support the new power
Engine: 5.0L TBI
Axle/Gears: 4.10
heck i just replaced teh friggin fuel pump, teh springs may have to wait, cuz i certainly dont want to take the rear end apart again.
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
no, valve springs. they are under your valve covers.
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
No, I think he meant that he didnt want to take the rear end apart to put a walboro in or something, after upgrading the springs, cam, or prom chip.
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
yea could go either way. torn between wanting him to know what he's talking about and saying it a confusing way, or getting a small laugh out of the idea of someone replacing rear springs to fix the valve train
. i really hope he didn't put a stock pump in, even new it isn't really,, suitable.
. i really hope he didn't put a stock pump in, even new it isn't really,, suitable. Last edited by rockit; Sep 20, 2007 at 11:54 PM. Reason: left alphabet soup on th screen
Engine: 5.0L TBI
Axle/Gears: 4.10
I did put a stock one in. I tried putting a high perf. one in, but it had too much power. burst the system and fooded the engine. Hence im running on a stock pump. and yes, i did mean taking the rear end apart to repace the pump. Im not a big enough idiot to confuse vave springs with rear end springs.
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
i didn't mean anything by it, hope you didn't take offence. you might want to check out your fuel pressure regualtor on the back of the tb, might have a problem there. in the process you could make it adjustable which is cheap, and has the potential of adding some power
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
I recently upgraded to a lt1 cam and it ads decent power in midrange. I think next step will be adjusting the shift points at slightly higer rpms to use that power.
Engine: gone
Transmission: gone
Axle/Gears: gone
the more air you getin to and out of the engine the more power you will make thru out the entire rpm range, focus on your air inlet system and your exhasut system.
RedLeader289
May 28, 2019 01:47 PM
Damon
Sep 26, 2015 04:29 PM
