POST pix of your engine bay-need locations of parts
Old Mar 14, 2008 | 02:43 PM
killacamaro's Avatar
Car: 88 IROC-z
Engine: LO3 V8 305
Transmission: T5 W/ Stage 2 Clutch
hey guys im finally putting back together my engine. im up to the point i wanna know what hoses go where. im using a edl-2101 intake with a holley TBI. i also need to know how to block off the egr or not use it at all. soo if u guys could please help me out, it would be greatful. the parts that are in the holes now, i think are wrong soo help will be helpful thanx
Old Mar 14, 2008 | 07:18 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: POST pix of your engine bay-need locations of parts
Old Mar 14, 2008 | 07:25 PM
thomas1976's Avatar
Car: 91 Trans am
Old Mar 14, 2008 | 07:34 PM
Car: 88 IROC-z
Engine: LO3 V8 305
thank you very much, but sum do and dont help. its a lil clusterd. do you know how to not use the egr valve?
Old Mar 14, 2008 | 07:42 PM
thomas1976's Avatar
Car: 91 Trans am
I have other pics from wenn I did the lt1 cam. You just need to tell what you need to see.
Sorry, I only know how to bolt everiting were it came from.
Old Mar 14, 2008 | 07:56 PM
Car: 88 IROC-z
Engine: LO3 V8 305
yeah thats wat im trying to do soo if u can help and show more it would be greatful thanx
Old Mar 14, 2008 | 08:16 PM
thomas1976's Avatar
Car: 91 Trans am
On the intake manifold there is not much more to show. Describe what you need. Also "ultimate lt1 cam" has complete documentation.
Old Mar 22, 2008 | 02:14 PM
Car: 88 IROC-z
Engine: LO3 V8 305
hey thomas well i am wondering in your 2nd pic there is 2 items. the black item is what i need to know where those vac lines run to. i also need to know what that round cylinder thing is on the back driver side of intake is. that has like a flat clip connector going to it.
also i wanna know how to tighten up my throttle cable. the pedal isnt as high as it used to be. sum play in it.
i found where everything else goes. just gotta fix vac lines.
also do you need that charcol canister? and how do i run my car without an EGR. i have the edl-2101 intake manifold and dont wanna use an EGR
Old Mar 22, 2008 | 03:28 PM
thomas1976's Avatar
Car: 91 Trans am
The top vacuum hose goes in the valve cover, the lower thinner one to the canister in the front left.
You intend the coil?
Im out of town till tuesday and have no acces to my pics.
About egr I dont kow.
Old Mar 22, 2008 | 03:42 PM
Car: 88 IROC-z
Engine: LO3 V8 305
Hey there. Ummm what do u mean intend the coil??
I will take pics of the stuff I need help with and then mb u can label them or list wat it is. Thanx.
Old Mar 22, 2008 | 03:47 PM
thomas1976's Avatar
Car: 91 Trans am
The coil is that black cilinder thigh between the distributor and trottle linkage, there are 2 wires going to it and the little piece of spark plug goes from its tip to the center of the distributer.
Old Mar 23, 2008 | 02:52 PM
Car: 88 IROC-z
Engine: LO3 V8 305
yeah i kno whawt the coil is. what im talking about is this part and this part, i need to know what each is, and what they are for.
also do you need the charcol canister? and that thing that looks like a bubble? that is for the choke i think?? do you need that?
Old Mar 25, 2008 | 10:37 AM
thomas1976's Avatar
Car: 91 Trans am
The black one you can see on pic 4 and 5, the short hose goes to the egr and the long one to front right port on the tb.
The other part? I never saw it.
I dont know what part you intend with charcol canister.
Old Mar 25, 2008 | 12:22 PM
xjcamaro89's Avatar
Car: 1989 Camaro RS
Engine: 350 Holley TBI Personally Tuned
Transmission: 5 Speed
Dont know if this helps anyone but heres mine.
Old Mar 25, 2008 | 10:20 PM
1montess's Avatar
1. The "bell shaped" copper lookin piece goes at the rear of the engine in a teeeny hole about 1 1/2 inches to the right of the distributor. I believe it to be an oil pressure deal. Has a tiny pinhole in it to send oil......
2. Your coolant temperture sensor(black plug w/ 2 pins in it) goes to the front of the engine and your heater hose adapter goes to the rear. Flip-flop them dude.
Good luck!
Azrael91966669
25
Jun 20, 2017 04:04 AM
InfinityShade
Aug 22, 2015 08:00 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
1nastygta
Aug 8, 2015 07:38 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
