Throttle Body Acting Really Wierd
Old Feb 21, 2009 | 04:18 PM
Dudeman1531's Avatar
Car: 91 Camaro RS
Engine: 383 FiTech
Transmission: T-56 BW
Axle/Gears: 3:42 10 Bolt
OK when the car is cold it will start right up but if i don't let it warm up it starts to lunge forward in first gear. Then when it is all warmed up and running great, ill turn it off and go somewhere for like an hour and when i come back i have to keep priming the engine until it warms up.
I just had the TPS changed and new Fuel Injectors.
Any clues to what im talking about??
Old Feb 23, 2009 | 03:03 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
When you say “prime” do you mean you have to squirt fuel into the throttle while some else cranks it?
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
How bout those dorks too scared to drive without headlights in the daytime!
Old Feb 23, 2009 | 03:08 PM
Car: 91 Camaro RS
Engine: 383 FiTech
Re: Throttle Body Acting Really Wierd
No I have to keep reving it up the entire time
Old Feb 23, 2009 | 04:05 PM
zapeee's Avatar
Car: 1995 K1500 Yukon 2-Dr and 1982 Z-28
Engine: truck: 350hp 454 car: 485hp 355
Transmission: truck:5spd car: Doug Nash 5spd
Axle/Gears: truck: stock car: Dana44 w 3:23
You mean you have to hold the pedal down to get it started, then keep your foot on the gas to keep it running?
just for shXts and grins, check to see if all of your sensors are plugged in and the wires look good and not mixed up. my truck has two temperature sensors that look similar, one is gauge, one is computer engine temp sensor, and when the computer temp sensor failed, it ran as above and got 1 mpg.
Old Feb 23, 2009 | 04:07 PM
zapeee's Avatar
gage sensor in driver's side cyl head, computer sensor in intake manifold near water neck (on my tbi trucks)
Old Feb 23, 2009 | 05:19 PM
ownor's Avatar
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
the sensor the computer sees is called CTS (coolant temp sensor) and sits close to the t-stat housing on the intake manifold. you can test your CTS using a volt/ohm meter, use the search on this board.
Old Feb 23, 2009 | 10:52 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Do you hear the fuel pump prime for 2 seconds when you turn the key forward but not on ? Maybe something in the pump busted allowing fuel in the lines to flow back into the tank or canister, canister could be full of fuel.
Old Feb 27, 2009 | 08:34 AM
Car: 91 Camaro RS
Engine: 383 FiTech
Thanks for all the Info Guys. Tried everything but a new fuel pump but its going to the shop today. Ill keep you posted as to what happens
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
