Any tbi cars over 300 rwhp and 300 rwtq?
Old Mar 3, 2009 | 08:47 AM
adm030's Avatar
Car: 92 camaro rs
Engine: lo3 305 tbi
Axle/Gears: 2.73 , 3.42 soon
I want to build a 350 roller block thats been rebuilt and bored .30 over, it will have patriot vortec heads, vortec rpm intake and comp cam( undecided) I was just wanting to see some builds and talk to someone thats running this much power with the tbi. I want around 300/300 and any more is great. Thanks
Old Mar 3, 2009 | 03:53 PM
adm030's Avatar
Car: 92 camaro rs
Engine: lo3 305 tbi
Re: Any tbi cars over 300 rwhp and 300 rwtq?
I was gonna do a lsx swap ,but a 350 tbi would be so much cheaper and easier, so let me know what yall think.
Old Mar 3, 2009 | 04:05 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
a 600 cfm TBI with minor mods and a good computer chip can get that kind of numbers, 454's had 600cfm TBIs, and holley makes one to
they also make a TBI to multi port conversion its a little pricy but it supports that kind of numbers and a little better
Old Mar 3, 2009 | 06:30 PM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
Hopefully, I am over 400/400 @ flywheel, but i need a dyno to prove that. Your build sounds good since you are matching components properly. I'm running a lt-4 hot-cam, so you should only need to run a cam with a lot less lift. (hotcam w/ 1.6s is .525 on int and exh)
Old Mar 3, 2009 | 08:06 PM
adm030's Avatar
Car: 92 camaro rs
Engine: lo3 305 tbi
Well I saw where a member with 355 rwhp and 348rwtq ran a 11.68 1/4 with 3.42 I think a mid 12 street car will be perfect. I read your profile do you have any track times and do you have an idle clip of that hotcam? Was it difficult to get it tuned? and are you using the stock tbi? I have been looking at the comp cams tbi cam 08-300-8. Thanks for your help.
Old Mar 3, 2009 | 08:23 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I built a 10.5:1 compression 350 TBI with a production LT4 camshaft and ported Dart Iron Eagle 180cc heads. Bored an edelbrock 3704 TBI intake to 2" and used a 2" 454 TBI and stock 350 injectors at 32 psi. Doug Thorley Tri Y's into 2 1/2" duals with X-pipe. Custom tuning tied it all togather. I made 324 RWHP and 306 RWTQ.
Old Mar 3, 2009 | 08:43 PM
adm030's Avatar
Car: 92 camaro rs
Engine: lo3 305 tbi
Thats about perfect, do you tune with ebl or moates equipment I see you can pretty much dial any combo in. I hope to get to where i can do the same. When you run that much psi on the injectors what fuel pump do you have to run?
Old Mar 3, 2009 | 08:53 PM
89_RS's Avatar
Car: 2003 F-150
Engine: 4.6L Modular V8
Transmission: 4R70W
Axle/Gears: Ford 8.8"/3.55 LSD
I think Fast355 may have broke the 300rw mark with his 310 even. He made 423fwhp & 415fwtq.
https://www.thirdgen.org/forums/tbi/...ferrerid=35855
Old Mar 4, 2009 | 10:36 AM
graebz28's Avatar
Car: 83 Z28
Engine: 406
I don't think I'll ever get tuned completely; there is too much to tinker with. I have it idle at 850 right now.
I just read the post on Fast's 310. I wish it didn't get lock cause it is an extremely good read.
Is the LT-4 hotcam considered old, inefficient technology? Is the comp cam really that much better? I may replace the cam some day and go with a bit more lift since my heads are rated for .600 lift. I think .580 would be the highest I go.
ANYWAY, back to your post. I am able to obtain 11-13 hg at idle. I wait until I get it a bit better, then get some sound clips (on the road right now).
Good Luck!
Old Mar 6, 2009 | 09:03 AM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
awesome
I think I have 150hp at the rear wheels
I have the dreaded Crossfire 305ci LU5 what kind mods do I have to do to get close to 300 hp or torque
Old Mar 8, 2009 | 07:36 PM
DeanJ's Avatar
Car: 1988 Camaro, 1986 S10, 2000 Harley
Engine: LS6
Axle/Gears: 3.75 9" ford trac loc
hi guys, I went to the dyno this past friday,280 RWHP,at 5200rpm. 326 ft lbs max torque. Vortec 350,lt1 cam, 2" throttle body, open element air cleaner, shorty headers into 3" single exhaust. T56 trans ,3:23 rear gears. EBL and I know the tune is not perfect. Wonder why so much torque vs horsepower ? Lt1 cam maybe? later, Dean
Old Mar 8, 2009 | 08:21 PM
DeanJ's Avatar
Engine: LS6
Hey again, a little more info I forgot. Professional Products dual plane intake,1.6 rockers. Here's the dyno printout!!!
http://thumb18.webshots.net/t/74/74/...8HJwLja_th.jpg
I have included the link incase the image doesn't enlarge.
Old Mar 8, 2009 | 08:47 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Very nice overall torque curve and power. That is about what I had predicted for my "BUDGET 350 VORTEC TBI" buildup. Production LT4 camshaft and a Single plane intake with a better set of headers would have pushed you over the 300 RWHP number.
hectre13
Dec 11, 2023 08:14 AM
MustangBeater20
Oct 29, 2022 09:20 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
89-S-dime
Aug 12, 2015 11:57 AM
