Error Code 43, I've searched without soultions! Please help me!!
Old Mar 16, 2010 | 06:40 PM
Garth Knight's Avatar
Car: Firebird
Engine: 3.1 V6
Hello everybody from Italy,
I have a 1988 Pontiac Firebird with the 305 V8 TBI motor (code E). I am getting code 43 (low voltage at electronic spark timing circuit, or functional test failure). I've bought a new ESC module, new knock sensor, new plug wires, new spark plugs and new distributor. I've checked and changed timing and octane fuel, with no results! Continuity in the wiring appears OK.
When the car first starts, it runs great for about 5 minutes, then upon heavy acceleration/hill climbing, there is hesitation, I hear a strange noise from the enigne (probably a detonation) and the SES light comes on (code 43). The car runs bad (hesitation, uneven idle, very sluggish) until I shut off the ignition, wait a few seconds, then restart (then the problem repeats).
I'm becoming crazy! I hope in your help! Thanks!
Old Mar 16, 2010 | 06:46 PM
xX89RSXx's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Re: Error Code 43, I've searched without soultions! Please help me!!
Check your ignition components: plugs, wires, coil and so on.
Old Mar 16, 2010 | 06:53 PM
Car: Firebird
Engine: 3.1 V6
Thanks for fast reply, I'll check tomorrow!
But do u think that the noise from engine before the SES light is normal?
Old Mar 16, 2010 | 07:27 PM
xX89RSXx's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
That noise could be a misfire, which would explain the hesitation and bogging down.
Old Mar 16, 2010 | 07:29 PM
Car: Firebird
Engine: 3.1 V6
I understand..
Old Mar 16, 2010 | 08:13 PM
Yuffie55's Avatar
Car: 1992 RS
Engine: 305 TBI
Transmission: 4L60
Axle/Gears: 2.77
hey i had a 1989 s10 with a 4.3 with the same probilty it the pick-up coil in the dist checked ign coil module ps do you tachjump around ??????
Old Mar 16, 2010 | 08:25 PM
Car: Firebird
Engine: 3.1 V6
Do u suggest to swap the ignition coil??
Old Mar 16, 2010 | 08:47 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Garth, the forced knock test is failing. Once the engine temperature is above the proper level the ECM will advance the spark timing to force the engine to detonate. This will be done under heavy load which matches your description.
Try using a lower octane fuel so that the engine will actually detonate and see if that clears up the problem. Also check that the distributor base timing is set correctly.
There are several threads on this where I go into more detail. Should be easy to find by using my name in the authors box along with some key words.
RBob.
Old Mar 16, 2010 | 08:58 PM
Car: Firebird
Engine: 3.1 V6
Hello Rbob,
I've red all your threads about code 43 and I've tried to use a cheaper fuel and tried a lot of base timings from 0 to 12 without any results..
Probably, in order to solve definitively this problem, I can buy a PROM without the code 43 control for my car, but I have to find someone that sell it!
Old Mar 17, 2010 | 05:14 PM
1988-305-tbi's Avatar
WHAT?
Old Mar 17, 2010 | 06:42 PM
91RS5spd's Avatar
Car: 1990 Camaro RS (IROC-Z Clone)
Engine: LO3
Axle/Gears: 3.08
Originally Posted by 1988-305-tbi
WHAT?
"hey i had a 1989 s10 with a 4.3 with the same probilty it the pick-up coil in the dist checked ign coil module ps do you tachjump around ??????"
it's a riddle, being a person living in N. Chas SC my self ill explain. This is what he/she was saying.
"Hey, i had a 1989 s10 with a 4.3. It had the same problem as your describing. It turned out to be the pick up coil in the distributor so i suggest to check that. One more thing, does your tach jump around?"
I hope that helps.
Old Mar 17, 2010 | 06:50 PM
Car: Firebird
Engine: 3.1 V6
Thanks! What means "does your tach jump around"?
Old Mar 17, 2010 | 07:54 PM
91RS5spd's Avatar
Engine: LO3
Axle/Gears: 3.08
It means your tachometer jumps around sporadically....it displays no stationary rpm reading.
Old Mar 17, 2010 | 08:24 PM
bcmag's Avatar
maybe the "noise" you hear is amechanical issue w/ engine.knock sensor cannot tell difference and continuously retards timg trying to stop what it believes is "pinging"causing poor driveability and ses/43.whole process repeats each drive cyle until engine is shut down and restarted.if it is detonation check for proper egr system function and flow.
Old Mar 18, 2010 | 04:00 AM
Car: Firebird
Engine: 3.1 V6
I underestand, my tach is regular, no trouble with it
Old Mar 18, 2010 | 04:02 AM
Car: Firebird
Engine: 3.1 V6
I will do, thanks
Old Apr 26, 2010 | 06:30 AM
Car: Firebird
Engine: 3.1 V6
Hello, this is the file log with WinALD, please help me, thanks!!
http://www.adrive.com/public/6729319...548c064d9.html
Old May 6, 2010 | 07:38 PM
gearhead1963's Avatar
i'm having the same problem....did you get yours running better?....if so what was it?..
Old May 6, 2010 | 07:52 PM
Car: Firebird
Engine: 3.1 V6
I don't know! I'm going to swap the Egr valve and solenoid, I've changed a lot of parts w/o success
Old May 19, 2010 | 01:11 PM
Car: Firebird
Engine: 3.1 V6
Finally problem solved!!! It was the ground wire to ESC module broken!!
Old May 19, 2010 | 01:47 PM
I found my problem. I went to change the knock sensor and it had permetex or sealant blocking the hole. The knock sensor was not into the coolant so it was not picking up the sounds in the motor so It set code 43 during the knock test.
wigmobile
Feb 26, 2025 02:56 PM
BumpaD82
Feb 26, 2016 02:57 PM
sahlomonic
Sep 20, 2015 07:15 PM
bubbaz28
Sep 18, 2015 02:09 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
