stock motor balancer
Old Jun 14, 2011 | 04:10 PM
IndyL03's Avatar
Car: 1993 Caprice
Transmission: 4L60
looking into a possible timing issue and was looking a blancer and the rubber has cracks all the way around. I wanted to know what is recomended for a stock motor. seen dorman, pioneer, proform. does one absorb vibes more than another. not look to sppend much must definitely dont want some bs [parts.
i went to check timing and the reading would be steady for a bit the get a few erractic movements so idk if the rotational force on pullly or both it and timing are a factor. 165,000. idle is starting to get a shake off and on afrter closed loop. when accelerating slow nothing noticed but with quick increase of throttle car bogs down a second and i get a miss or two. makes me think the chain is stretching with load.
Old Jun 14, 2011 | 08:16 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: stock motor balancer
A dorman product is fine. Probably going to be the cheapest. I am using one of those tiny pioneer ones and I have had no problems. Been on my car for years.
Old Jun 16, 2011 | 08:33 PM
IndyL03's Avatar
Car: 1993 Caprice
Transmission: 4L60
well i know i cant do pioneer but just seeing. i also seen 2 different sizes . does that effect the belt? or any advantage for one size vs the other?
Old Jun 16, 2011 | 09:26 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
a smaller damper puts less drag on the rotating assembly helping you rev faster and stuff. The damper size does not affect belt length as the belt length is determined by the crankshaft pulley.
Old Jun 17, 2011 | 03:20 AM
1992COUPE's Avatar
Car: 92 RS 25TH ANNIVERSARY All original
Transmission: T5 WORLDCLASS
Axle/Gears: 3.08 OPEN
do you want to go back with OEM part. I can help you with this. Part number 12551849. Somewhere around $80.00 should do it.
Old Jun 17, 2011 | 11:20 AM
xX89RSXx's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Summit has oem replacements for $53 or so.
Old Jun 20, 2011 | 04:51 AM
IndyL03's Avatar
Car: 1993 Caprice
Transmission: 4L60
well that part number didnt come up with anything. think ill just go with the dorman replacement. just need something basic. took a good look at mine earlier and the rubber is sunk in random places. hope the basic cloyes timing set will suffice. original one has made it 18 years and just now showing signs of being stretched.
Old Jun 20, 2011 | 04:56 AM
IndyL03's Avatar
Car: 1993 Caprice
Transmission: 4L60
did see the gmpp set but from the posts ive looked at its been mixed emotions about it. found it for 1 dollar difference over basic cloyes
Old Jun 20, 2011 | 10:49 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
You can get a nice single roller chain for 80 bucks or so cloyes, comp, etc..
Old Dec 11, 2011 | 07:31 PM
IndyL03's Avatar
Car: 1993 Caprice
Transmission: 4L60
i went with the basic cloyes. i did notcice the timing is advanced like crazy but never notice anything while driving
Old Dec 11, 2011 | 07:49 PM
Damon's Avatar
Cloyes makes many different quality level chains. If you went with the $20 cheapie, you bought a crappy cain set. The absolute dirt-cheapest chain set I've found that won't stretch like salt water taffy in only few thousand miles is the Summit house brand true roller (about $35 for use with falt tappet cams). Anything cheaper is junk. The GMPP single roller chain set is an excellent one for use with a FACTORY ROLLER-STYLE cam and is high quality despite the fact it's only a single row chain. It also fits under all stock timing covers and clears the top oil galley boss without grinding.
Old Dec 14, 2011 | 11:38 AM
Schurkey's Avatar
The thing does not BALANCE anything on your engine.
Better name is "Torsional Damper". Some folks call it a vibration damper, and that's accurate too. Some dampers (400 and 454 Chevy, for example) have some affect on engine balance--but calling them a damper is still accurate.
Most any low-dollar aftermarket damper is going to be Made In China. Good luck with them. Ever seen what a Chinese damper looks like after it explodes?
Be sure the unit you buy has the timing mark in the correct place to match your timing pointer.
Old Dec 14, 2011 | 11:39 AM
Schurkey's Avatar
CAM timing, or IGNITION timing?
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
italiano67
Dec 11, 2016 09:21 AM
InfinityShade
Aug 22, 2015 08:00 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
mustangman65_79
Aug 8, 2015 01:18 AM
