Check Engine Light
Old Nov 6, 2011 | 07:22 PM
3318RS's Avatar
Car: 1990 RS
Transmission: Built-700R4
Check Engine Light
I recently removed all the smog equipment from the car. I get the check engine light after the car has warmed up (running for 10 + minutes). The car runs perfect, but this is new.
Is this because of the smog pump removal? Do I need a tune/chip to override this?
Old Nov 7, 2011 | 01:54 AM
RS-Chevy-SS's Avatar
Car: 1989 Chevy Camaro RS
Engine: L30 TBI 5.0L Vortec
Axle/Gears: Stock
Re: Check Engine Light
Ive been pumpless for like 4 years, no CEL
Old Nov 7, 2011 | 03:57 AM
3318RS's Avatar
Car: 1990 RS
Thanks! I will look elsewhere for the CEL source.
Old Nov 7, 2011 | 07:52 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Blink out the malfunction codes. Odds are it is for the EGR.
RBob.
Old Nov 7, 2011 | 06:29 PM
3318RS's Avatar
Car: 1990 RS
RBob.
Thank you!!
PS Ignore my ignorance, what exactly do you mean by "blink out"?
Old Nov 7, 2011 | 07:11 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
can't you just remove the bulb?
Old Nov 7, 2011 | 07:16 PM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Axle/Gears: 3.42 Posi
If you don't have a code reader or aldl cable you can use a paperclip on the aldl plug to set it into a diagnostic mode. It will blink the error code # when you turn the key forward which you can reference for the actual error its throwing.
Old Nov 7, 2011 | 07:19 PM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Here is what you need to know:
http://www.freeautomechanic.com/diag...blecodes5.html
Old Nov 7, 2011 | 07:47 PM
3318RS's Avatar
Car: 1990 RS
Originally Posted by bluers91
Wow great link, thank you!!!
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
