I got a 89 TBI motor (I put in my 86 T/A). I finally got it back together and running but I have a question about the air cleaner. I pulled the motor out of a 89 Camaro and parted the car myself so I know I have all the parts, but it has been a slow process or fixing this car.
I tried to put what I think is the stock air cleaner back on but it does not fit. I am pretty sure it is the stock air cleaner because it has the hole in the bottom for the sensor. The 86 Carb'ed air clearner that came off the T/A did not have that hole. But when I attempt to put the air cleaner on, it hits the cable on top ( I think that cable is for cruise control).
So is there a spacer that goes between the TBI and the air cleaner on that engine? My 89 truck has the same set up and has a spacer there so should the Camaro motor?
If so I gotta find it, garage is kind of a mess right now.
Quote:
Ok so there is a spacer then. About how tall is it? I have to sort through all the parts in the garage and find it then. Originally Posted by ex-x-fire
The spacer goes between the tbi & the air cleaner. Thanks.
Good work guys...there is the spacer!
Excellent thank you!!! Now I know what I am looking for. Thank you very much for posting the picture.
Quote:
Excellent. Thank you for the offer. I should have it just gotta search the garage. I have not have much time too look. I'm moving from one garage to another right now and trying to keep organized. I am now seeing how many car parts I have laying around!!Originally Posted by ratrapp
if you can't find it i've got an extra one.
