car wont run shuts off when trying to idle
Old Dec 14, 2012 | 08:15 PM
Wayne91rs's Avatar
1988 firebird 305 tbi
Car starts up quick and then shuts off when trying to idle. I have to keep pressing the pedal to keep it on but it idles extremely rough and then shuts off. So far we've replaced spark plugs and wires. Distributor and module. Rebuilt the throttle body and iac valve. Checked vaccuum lines and loose wires... Tried to check codes but engine light wouldn't flash for codes and also tbi shoots out what seems to be fuel like it backfires. Any ideas here? Thanks for the help...I'm completely lost
Old Dec 14, 2012 | 08:16 PM
Wayne91rs's Avatar
Re: car wont run shuts off when trying to idle
Also replaced the fuel filter and gas is good.
Old Jan 18, 2013 | 06:06 PM
Jk_Under's Avatar
Car: 91 Camaro RS, 84 2.8 5speed
Engine: 305 5.0L
Transmission: Auto, 5 speed
I am having the same issue. It ran fine, just quit when idling. Fuel filter and pump replaced. Good Fuel pressure.
Old Jan 18, 2013 | 11:02 PM
dads old blue 9's Avatar
Car: 1990 z28
Engine: 5.0
Transmission: t-5 wc
Axle/Gears: 4th gen 3.42 posi
rubber line in fue ltank that conects the pump to the metal pick up splits . do a pressure ck doesn't matter that you can see fuel in the tb and hear pump kick on . ran fine then all of a sudden this happened rite?
Old Jan 20, 2013 | 09:12 PM
RammRodd's Avatar
Car: 1989 Trans Am
Engine: 305 5.0
Had same problem with my 89 TA... checked / replaced injectors... fuel pressure ok (well, comes out of thing on engine when you press it down) and still wouldn't idle.
Been driving it for last 2 years with the mass air flow sensor disconnected. Starts and runs great like that, but car won't run with it connected. Even replaced it with new one and it won't run with it connected.
Idols ok too... maybe a little high... usually 800 - 900.
Don't ask me, but see if yours idols with the mass air flow sensor unplugged.... I'd be interested to see if that fixes it.
Old Jan 21, 2013 | 11:09 AM
Car: 1990 z28
Engine: 5.0
I am convinced that waynes problemis in the tank. wish he would give us an update , as its been a while since his post . Whats up wayne?
Old Jan 21, 2013 | 11:11 AM
marballfire's Avatar
Car: 88 Camaro SC
Axle/Gears: 3.42 POSI
Check coolant temp sensor. Mine crapped out and the car would flood out at idle unless i held the throttle open a bit.
Old Jan 21, 2013 | 11:25 AM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
I would additionally check the IACV (Idle Air Control Valve)...
Old Jan 26, 2013 | 10:44 PM
goliath88's Avatar
Car: 88 firebird convertible
Engine: 305 tbi v8
two votes for fuel tank. . bad pump or the hose is broken inside...
Old Jan 27, 2013 | 09:07 PM
Josaiah89Iroc's Avatar
Car: 89 Iroc Z28 Camaro
Engine: 305 V8
It is probably a MAF Sensor issue. Try using some MAF cleaner on it and see if that helps
specialized
Jun 18, 2022 09:26 AM
Wade787b
Sep 29, 2015 01:15 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
