No fuel!
Old Mar 9, 2019 | 02:41 PM
Jesse Mortensen's Avatar
No fuel!
Cranks but no fuel. Replaced relay,fuel pump, oil pressure sensor still nothing. Is there any other sensor that could cut fuel in any way on a 1991 RS 305 tbi? Rear impact sensor?
Old Mar 9, 2019 | 03:18 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: No fuel!
Vats, no injector pulse ?
Old Mar 9, 2019 | 08:12 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: No fuel!
Original TBI injectors?
Old Mar 10, 2019 | 06:21 PM
Schurkey's Avatar
Re: No fuel!
1. Does the fuel pump run for two seconds when the key is turned from "off" to "run"? If the fuel pump primes, it's not the fuel pump relay. If the pump runs when the engine is being cranked (has oil pressure) it's not the oil pressure switch.
2. Do you have spark? No fuel, no spark = distributor or wire harness problem. ECM requires distributor pulses to turn on the fuel injectors. No pulses, no fuel spray.
Old Mar 10, 2019 | 09:35 PM
Re: No fuel!
Can't hear the fuel pump run or prime. I've got spark. What is the sensor on The back of the rear end pumpkin? This problem happened driving on a hot day on the freeway. Just lost all fuel all of a sudden. Replaced the fuel pump then ran good for 1 1/2 hour drive then lost all fuel again.
Old Mar 11, 2019 | 11:46 AM
Schurkey's Avatar
Re: No fuel!
What is the voltage on the fuel pump + wire near the fuel tank when the engine is cranking? Should be within a couple of volts of battery voltage
What is the voltage on the fuel pump - wire near the fuel tank? Should be less than 2 volts, less is better.
I've got spark.
Have someone crank the engine while you listen to the injectors. You should hear them clicking. (They won't spray fuel if there's no fuel pressure.)
No idea. Sure you're not seeing the brake plumbing, or the axle vent?
Did you replace the short wire harness from the fuel pump to the fuel pump hanger connector? They're known for corrosion.
I figure it's most likely you have a bad wire--corroded connection, broken, pinched, something like that--between the engine compartment and the fuel pump--or between the fuel pump and ground. 'Course, it could just be a plain ol' defective pump. If it was a plugged filter or filter sock, you'd hear the pump run during "prime".
Old Mar 15, 2019 | 07:41 PM
Re: No fuel!
There is a plug riveted behind the backseats under the carpet and it plugs in underneath the car above the rear end. Plug-in runs up to the fuel tank is this a sensor or just a connection point?
Old Mar 15, 2019 | 08:07 PM
Engine: Lb9
Transmission: M20
Re: No fuel!
The riveted connector is just a body pass through connector. No spliced in this connector. The pump power/ground and gauge sender connector is located by the tank.
Are you not getting power through C100 to the pump ?
Old Mar 15, 2019 | 09:15 PM
Re: No fuel!
Can I access any fuel tank/gauge wire’s from underneath?
Old Mar 15, 2019 | 09:18 PM
Engine: Lb9
Transmission: M20
Re: No fuel!
Yes, It’s next to the tank. A 3 wire connector.
kowboy59
Nov 7, 2011 09:36 PM
Hokies83
Aug 21, 2010 12:48 PM
babybear82lilj
Feb 5, 2008 05:12 PM
michael
Jun 24, 2001 08:16 AM
