LO3 ECMs
Old Jun 19, 2022 | 08:13 AM
sleeper84's Avatar
Car: 1989 RS
Engine: LO3 5.0L
Axle/Gears: 10b 2.73
LO3 ECMs
I picked up an ALDL cable and downloaded the ALDLdroid app to start logging.
My car is titled a 1989 but the line set sheet is dated 11-88. So I tried the 746 mask but didn't get much data. Swapped to the 165 mask and got lots more info. My coolant temp seems to be incorrect though. Cold start was 188 and went down as engine warmed up.
Is there any major advantage to one ECM or the other? I have a 1992 LO3/Auto ECM in a parts car if the later ECM is any better.
Old Jun 19, 2022 | 08:26 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: LO3 ECMs
Tbi used $61 mask in 89/92
Old Jun 20, 2022 | 08:33 AM
sleeper84's Avatar
Car: 1989 RS
Engine: LO3 5.0L
Re: LO3 ECMs
Where is the best $61 .adx available at? Looks like the app uses a 58 .adx
Old Jun 20, 2022 | 08:54 AM
Engine: Lb9
Transmission: M20
Re: LO3 ECMs
http://www.gearhead-efi.com/Fuel-Inj...Information-61
or
http://www.tunerpro.net/downloadBinDefs.htm#GM
convert the ads to adx
Old Jun 21, 2022 | 01:15 AM
Schurkey's Avatar
Re: LO3 ECMs
November '88 would be an '89 model year vehicle.
Old Jun 21, 2022 | 05:04 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: LO3 ECMs
A083 is the correct data stream for the '89 - '92 TBI f-cars (VIN E).
RBob.
Old Jun 21, 2022 | 08:09 AM
sleeper84's Avatar
Car: 1989 RS
Engine: LO3 5.0L
Re: LO3 ECMs
RBob.
I'm pretty certain it's the earlier ECM. Hooked up with Tunerpro and used the $4D mask (88 LO3 only) and got good knock values where the $61 mask kept giving me an ERROR in the knock field.
Old Jun 21, 2022 | 05:23 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: LO3 ECMs
OK, ECM could have been swapped. Drop it down and get the BCC off the chip and the Service Number off the ECM. Then we will know what you are dealing with. Otherwise we can't see the ECM from here...
For an '88 f-car, use A41.
RBob.
Vinscully50
Apr 11, 2022 10:48 AM
lethaldomestics
May 10, 2016 11:49 PM
r0nin89
Apr 12, 2006 04:41 PM
nicks_ss
Mar 21, 2001 04:04 PM
