Very wierd!!! Key stuck in ingnition in "crank" position...
Old Apr 19, 2002 | 03:47 PM
Beast5spdGTA's Avatar
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
Went to start my car, started fine, figured out the car thinks it stuck in the "crank" position i.e. no power windows, temp gauge is pegged, E-brake like on even though the brake is off, etc. I got the car home and also noticed that the alt. isn't functioning since the car promptly stalled out when I disconnected the battery.
Questions... How do I get the keys out? Any clue on what to do/how to fix this problem?(tear apart streering column?) I got the keys to shut off the engine one time, but car almost didn't re-start(side of road) and definately can't get them out now, I tried for 15-20 min playing with the steering wheel, key lock lever etc...
Old Apr 19, 2002 | 05:28 PM
86Tra/maro's Avatar
From: Newark,NJ The state where racing on I 78 rules.
Try checking out the lockout on the trans.Its connected to the gear selector cable
Old Apr 19, 2002 | 06:51 PM
CAMARO82's Avatar
Same thing happened to me about 2 months ago, I had to replace my whole Ignition swicth which means getting a new key and all. Mines worked fine ever since So might try it :lala:
Old Apr 19, 2002 | 08:16 PM
Engine: LS7
This is a manual tranny.
That's what I'm worried about, how hard is it to pull the ingition and also what did it cost you? Sounds like i may need to get an ingition puller or something like that?
I can turn the key a little forwards(like to start the car) but I can't get it to turn backwards at all.
Any suggestions for how to tackle the steering column? Can I get to it from the behind the turnsignal stuff? I have steeringwheel radio controls as well.
Old Apr 21, 2002 | 01:49 PM
Engine: LS7
ttt
Old Apr 21, 2002 | 01:58 PM
Snowdog 91 Formula's Avatar
TILT Mechanism
Check your tilt mechanism if you have a tilt wheel!!!!
Same thing happened to my wife's 89 bird.
Once I was able to lock the wheel correctly, the keys turned fine.
Old Apr 21, 2002 | 09:05 PM
Engine: LS7
Could you please clarify what you said in that last post. I tried moving the wheel/column to different positions with no luck, no sure if that's what you meant? I think I'm only one 25T torx screw away from taking out the whole ignition key and all so I'll get that tomorrow and see. I have it so the key will get to the "run" position, so it's not so bad now, just drains the battery and makes my car easy to steal.
Old Apr 21, 2002 | 10:10 PM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
99% of ignition key problems are due to lack of service. If you can get some dry powder graphite (hardware store) squeezed into the ignition most likely it will straighten itself out.
<A HREF="http://www.gmtips.com/3rd-degree/dox/tips/misc/key.htm">Key Stuck In Ignition Article</A>
Old Apr 21, 2002 | 10:41 PM
Tilt/Lock
This is a manual transmission, but if you check to be sure you are in Neutral or first, and the E-Brake on, plus the tilt mechanism so the wheel is straight...
On Automatics it is Park.
Turn the key towards the ACC and try to get the steering wheel to lock.
Once that happens, the mechanism might be lined up and your key will come out with ease. If not, try the other recommendations.
Good luck!
Old Apr 22, 2002 | 12:35 PM
Engine: LS7
Well, I'll try the graphite to try and free it up as a spare, but I just went out and bought a new cylinder and key $82 ($52 for cylinder + $25 for a new key). It's definately the cylinder mechanism since she starts great now with needle nose pliers.
p.s. I broke off one of those plastic tabs mentioned trying to turn the key and did pretty much everything that article said minus the graphite powder(lubercation). Thanks for the help.
3rd gen money
Oct 11, 2019 09:57 PM
RS Reaper
Oct 17, 2018 07:52 PM
Gunner242
Dec 25, 2015 04:49 PM
Linson
Oct 1, 2015 09:50 PM
lanceflame44
Sep 25, 2015 12:28 PM
