dyno numbers sound right for this car?
Old Apr 27, 2002 | 11:32 PM
matt87's Avatar
had a Buick dyno day today and i invited my friend who owns an 86 305 iroc with the 700 4r tranny. well after a few passes we got he best of 192 hp and 260 ft pounds of torque. he was disgusted but i told him i thought that was about right. his engine is nearly stock with headers, adj fuel pressure reg, 24 pound injectors. not much else. he was a little amazed too when my little ol' six made 440 rwhp and 450 rw torque!
Old Apr 27, 2002 | 11:36 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I'd say that's damn good, I take it it's a TPI??
OH, and 440 rwhp, :hail: :hail: :lala:
Old Apr 27, 2002 | 11:43 PM
matt87's Avatar
yes Mark its a tpi car and i know its got more in it, i told him those injectors are making rich with the stock prom he was using. we turned the fp down and each time it improved on the dyno. it then got too lean and bumped it back up to maintain his 192 rwhp numbers.
Old Apr 27, 2002 | 11:50 PM
Car: 99 Formula
Axle/Gears: 342
Stock it only has 190 HP at the crank, so I say he's doin pretty good with the mods he has.
Old Apr 28, 2002 | 12:14 AM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
yeah thats a storng running car there. Those injectors aer definately hurting him though. the ECM still thinks its firing 19lber's so its going to hurt performance.
Old Apr 28, 2002 | 12:40 AM
shrp1's Avatar
Re: dyno numbers sound right for this car?
Hey Matt whats with the TQ #'s they seem a little low??
Phil
Old Apr 28, 2002 | 10:47 AM
matt87's Avatar
shrp1, i have a 214-210 billet roller. i've notice from other dyno days the cars with stock cams make a ton of torque down low then fall off quickly before 5k. an aftermarket roller like mine has a nice torque curve that ramps up almost the same as the hp right up to redline, almost like an ls1.
Old Apr 28, 2002 | 04:32 PM
iroc22's Avatar
I thought in 86 they made 215hp.
In any event, those are excellent #'s for that 305.
Old Apr 28, 2002 | 07:51 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
Actually it was in 85 they had 215hp. Then in 86 CAFE came into play and the hp level dropped to 190 til like 88 or 89 I can't rememebr which one.
Old Apr 28, 2002 | 07:58 PM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
Isn't the reason for the lower HP is the cam GM put in the car? I know my cam is just way too mild and is hurting my performance badly.
Old Apr 28, 2002 | 08:01 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
192 RWHP is good on a mostly stock motor, Hes probably looking at 230 or so at the crank. He shouldnt be that disgusted.
Old Apr 28, 2002 | 10:51 PM
iroc22's Avatar
Yeah they got the peanut cam.
Old Apr 30, 2002 | 12:22 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
440 is about right for a boosted 6
I think supras are 415 with work. I take it your pulling 14psi with some head work?
I would think that would be a little quicker. How much that thing weigh? 3800+?
Old Apr 30, 2002 | 03:02 PM
matt87's Avatar
jcb999, what are you talking about? what would be a little quicker? my buick compared to a supra? my car has aftermarket aluminum heads, billet roller cam, 72# injectors and much more. it made 440hp untuned and it has at least another 80-100 hp left. the time in my sig is for stock block street gn.
Old Apr 30, 2002 | 04:23 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
i was talking about the times 440rwhp should generate
11.9-12flat is a little on the slow side. Your average 02-z06 is about that speed and is probably about 360rwhp with 3100 lbs. Since you have about 20 percent more hp than a z06, that would be about right for something weighing about 20 percent more than a z06 (or about 3750lbs). I thought GNs were a little lighter than that... maybe not.
Not too familar with GNs but I would think it would be quicker than that.
Old Apr 30, 2002 | 06:55 PM
matt87's Avatar
jcb999 the times in my sig are for my stock block,full weight t-top gn. i'm sure it weighs around 3700. that car went 11.92@117 and it dynoed 390rwhp. look at the trap speed not the et. the car doesnt hook worth a dime on nitto drag radials. thats a 100%street car. my other gn is lightened up a bit, has serious motor and suspension mods. it will be a high 10 second car.
Old May 1, 2002 | 06:34 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
actually I was looking at both speed and time
But,, that time/speed would be about right for 390rwhp and 3700lbs. I was thinking it was the 440 combination,.
1992 Trans Am
May 10, 2023 07:19 PM
MustangBeater20
Oct 29, 2022 09:20 PM
1984HO
Mar 19, 2021 11:59 AM
MY87LT
Aug 17, 2015 08:43 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
